Nitrous Oxide N20
Can get a Wet Nitrous System Cheap...Opinions??
Old 05-31-2012, 01:14 AM
FasterIsBetter's Avatar
So I can get a $500 Nitrous System locally for pretty cheap. Its a 75 Shot NOS Sniper Kit. Guy wants $60 for it. He ran it on his 2JZ-GE Lexus. I saw the car and it ran nice with the Nitrous Shot, but he wasn't tuned for it so that engine was most likely a ticking time bomb. I'm debating on running this for a little extra bump and to spool the turbo a lil quicker. I believe someone else ran one on the ZZP Turbo Kit and then went even bigger turbo. I'm debating on running it and if not I suppose I could sell it to someone on the forums. It has the big 20lb tank with it and I have looked at the kit myself as he sold it to a friend of mine with a 2008 IS250 but he decided he's swapping to a 2JZGTE, it is by no means a junk kit from what I saw of it.
Old 05-31-2012, 01:24 AM
EXsoccer1921's Avatar
weren't you just having trouble with you engine?
Old 05-31-2012, 01:28 AM
Nope, input shaft bearing went on the trans. Decided I'd take it to ZZP for 4.45 gears and a rebuild.
Old 05-31-2012, 01:35 AM
oh. thought you were running in to some other problem after break in
Old 05-31-2012, 01:36 AM
ItalianJoe1's Avatar
The sniper shot isn't $500, can be had for under $300. But that's still a great deal.
Old 05-31-2012, 01:42 AM
Well, worst case is I just get an intercooler sprayer I suppose.
Old 05-31-2012, 01:47 AM
Nope, just cam table issues and it would put out a puff of smoke when it sat and idled til the rings seated. Everyone had the same issue I had when running the cams though. Dead spot around 1krpm-2krpm with jerking. I didn't even get the 1st log sent to Matt due to bad weather before the trans went. I'm sure ZZP can straighten that out in the tune when I bring it up as its getting dyno tuned on E with the 5th injector and 340lph pump. Hoping to be a lil above 500 at the wheel on E for weekend runs and have a 93 tune for DDing it when I don't wanna drive the truck.
Old 06-04-2012, 11:25 AM
MotorCityMadman's Avatar
Yeah I have that kit and it is great. But you will need a pressure gauge and bottle heater though.
Old 06-04-2012, 10:00 PM
gone_in_10_sec's Avatar
i second that, to work properly.. without the bottle heater you'll use only half the kit's potential.. the bottle heater make the NOS flow faster, and once you have the kit install GET TUNED!!
Old 06-04-2012, 10:07 PM
brycerice13's Avatar
Just make sure the solenoids are good. If not don't buy it. Test them if you can. They go bad if you don't use them for a while, or if they got too hot. I used to have nitrous on my jeep.
Old 06-05-2012, 12:50 AM
He already sold it but I think I'm gonna buy a new kit and spray the front mount. Won't need tuned for that and I won't have the kit soon enough for when I'm up at ZZP.
Old 06-05-2012, 12:52 AM
You were who I was thinking of that runs nitrous. Couldn't think of your forum name, lol.
Old 04-07-2013, 11:57 PM
hucks1987's Avatar
please for the love of god. do not spray n02 on your interooler, spray c02. its so much cheaper..... DEI had the cry02 kit. works like a dream. also its alot cheaper then n02 to refill.
turbochargedss2012
09-20-2023 12:17 PM
bigdeertz
11-17-2016 09:41 AM
01-12-2016 12:01 AM
patooyee
10-15-2015 05:11 PM
nathan112i
09-30-2015 07:12 PM
Quick Reply: Can get a Wet Nitrous System Cheap...Opinions??
