View Poll Results: Nitrous or Methanol?
Nitrous Oxide
54
76.06%
Methanol Injection
17
23.94%
Voters: 71. You may not vote on this poll
Got GM Stage 3, Nitrous or Methanol?
Just ordered my GM stage 3 from Crate Engine Depot (BTW, Thanks for the awsome deal Tom!! ) so now my question is:
Should I go with the recommended dry 50 shot of Nitrous?
OR
Should I go with Methanol?
I already purchased my methanol injection kit from coolingmist.com. Looks real simple to install.
Should I keep it? or sell it and buy a Nitrous kit? I personally wanted to go with methanol... but what do you guys think?
OR
DO NOT USE A METHANOL KIT WITH THE GM STAGE 3 KIT!!
DO NOT USE A WET SHOT WITH THE GM STAGE 3 KIT!!!!!!!!
The kit is designed for a DRY 50 shot ONLY!
Especially for a 50 shot...there is NO reason to use a wet kit. Specially, when the PCM and tune is designed for a dry shot...save yourself 200 bucks or send it to me if you just want to throw it away.
BOTTOM LINE: If you are not going to use the kit the way it was designed, you should just get a tune and spray a wet kit or use your methanol.
This is how guys blow **** up on here and the wonder...What happened? Why?
FOLLOWING DIRECTIONS FTMFW!!!!
Or to not use it the way it was designed.
I see no point installing something as expensive as S3 without using the nitrous function.
FNFAST, I already found out it doesn't work with the S3. I'm selling the kit right now, I already bought my 50 Dry Shot. Im going all GM except the header and downpipe. After all, they designed and built the car, they know whats best for it.
FNFAST, I already found out it doesn't work with the S3. I'm selling the kit right, I already bought my 50 Dry Shot. Im going all GM except the header and downpipe. After all, they designed and built the car, they know whats best for it.
I hope you know I wasn't ripping into you at all, I was just stating my opinion
I have the stage 3 so my PCM controls the spray which means I can spray my dry 50 shot anywhere after the MAF. I have mine under mounted on my intake so you can't tell I'm spraying :
FNFAST when are going to post some photos of the setup from your own photos and run that thing at the track?
I have photos...whats your email address?
I slapped a 12.05 @ 115. But I got a lucky 60'. I should be right about 12.15 @ 118.
Please, post some pics of the nitrous setup. I will be installing on friday stage 2 with stg3 pulley (2.99") , GMPP exhaust, honed exhaust manifold and dual-pass endplate. After this I will be doing stg3 PCM and nitrous dry shot. Include photos of were you will spray.
Jose
stock 06 ss/sc
Jose
stock 06 ss/sc
Jose
stock 06 ss/sc
Jose
stock 06 ss/sc
Will GM install the 50 shot of nitrous at the same time they put in a Stage 3? I have the Stage 2 right now. Also hate to sound like a nube and I know the PCM controls the spray, but what exactly does that mean?
Originally Posted by Crateenginedepot.com
How does the Nitrous feature work?
A Nitrous system can be wired in so that the Stage 3 PCM provides the proper control scheme for a 50-shot of Nitrous when the Nitrous trigger is activated. The feature will only enable when the clutch is not depressed, throttle is at 90% or more, rpm is between 3500 and 500 below the rev limit, and no errors are detected.
What Nitrous kit does this work with?
The Stage 3 kit will work with any brand 50-shot Nitrous kit. It was designed around a dry system
You could hook up a 100 shot if you wanted to. Just FYI.
Thanks Pyros, that was really helpful. As far as the "Nitrous trigger" goes they are referring to anything along the lines of a Fast &Furious style steering wheel buttons? lol
