Nitrous Oxide N20
Installing Zex Kit
Old 01-27-2010, 12:41 AM
Sizzle06's Avatar
Installing Zex Kit
I'm going to be installing a zex kit pretty soon and need to know what wire i need to tap for the tps or wot sensor.Thanks
Anybody?
Old 01-27-2010, 08:39 AM
Sizzle06's Avatar
Old 01-27-2010, 09:43 AM
rico's Avatar
tvs + nawwss.. word?
Old 01-27-2010, 03:15 PM
Sizzle06's Avatar
Only about a 50 shot
Old 01-27-2010, 03:18 PM
rico's Avatar
EEE niceeee
Old 01-27-2010, 03:23 PM
Sizzle06's Avatar
I need to keep up with all you turboed LSJ's!!
Old 01-27-2010, 03:24 PM
rico's Avatar
i might have to add meth or a shot my self then
Old 01-27-2010, 03:31 PM
Sizzle06's Avatar
That would be a fun run
Old 01-27-2010, 03:39 PM
rico's Avatar
sure would .
Old 01-27-2010, 04:02 PM
bluechevycobaltss's Avatar
https://www.cobaltss.net/forums/show...nitrous&page=2
i have the zex kit also i havent tried to install mine yet but if you look in the link i think its post 21 that says its a purple wire coming off the throttle body, i thought i read some where you need a resister or something like that not 100% sure hopefully someone else will chime in and say exactly what ya need but that is at least the wire you need.
Old 01-27-2010, 04:36 PM
Sizzle06's Avatar
Ok thanks
Old 01-27-2010, 11:33 PM
Sizzle06's Avatar
Old 01-28-2010, 10:49 AM
superbug's Avatar
you will need to put a resistor on that wire to or it wont work. found out that the hard way since it wasn't in my instructions.
Old 01-28-2010, 06:54 PM
Sizzle06's Avatar
What size resistor?
Old 01-28-2010, 07:22 PM
superbug's Avatar
82k 1/2 watt....I think...I'll have to go look at my extras to be sure
Old 01-28-2010, 07:35 PM
rockSTAR_SS's Avatar
I have the Zex kit installed. I can confirm for you that the purple wire off the throttle body connection is the correct wire to tap into.
Have fun and good luck with your kit!
Old 01-15-2011, 05:09 PM
slobaltzzp3's Avatar
what was the "hard way", i just installed my zex wet kit and ever since i hooked up the TPS wire to the NMU i have been getting a P0507 code and the car feels like absolute poop! It is only if the car sits for a couple minutes (stop lights or whatever) then when i go to get on the gas it boggs down to the point where it almost stalls. and even when i get going it feels like its hitting fuel cut and sputters. I cant take it anymore! i tested the TPS wire and it shows .7 volts at idle and 4.2 volts at WOT.
Old 01-16-2011, 10:00 PM
BlkWdoSS's Avatar
Purple wire or green wire, they are the same except one is a rising signal and the other is a falling signal
im not using a resistor on my car and havent received any issues...
slobaltzzp3, how did you connect into that line? the problem you are having is because your TPS signal isnt being seen as matching from the pcm, because of the voltage change,
remove the throttle connector and make sure none of the pins are bent and all wires are pushed in entirely
l8r,
PD
Old 01-16-2011, 10:56 PM
i just removed some of the insulation on the purple wire and soldered the wire for the NMU to that. The buddy of mine that helped me run wires and stuff thought that you had to take the purple part of that connector off to remove the whole connector from the TB, Everything is set up and run threw the car and looks great! thanks blkwdoss! great deal, just have to fill the tank. i have been holding off on filling it due to snow and the whole TB issue.
Old 01-16-2011, 11:38 PM
BlkWdoSS's Avatar
the purple part? do u mean the retaining clip in the back of the connector? holds all the wire connectors snuggly into the connector? if so I would most definitely check all of the connections there
l8r,
PD
PS - you are very welcome, let me see some numbers or vids of passes once you get it going and thank you a lot, helped me out of a tight spot and got me into my tuning class this weekend
Old 01-17-2011, 12:59 AM
yea, the purple retaining clip, and i did what you said and the issue at hand has not arrived.
and there will def. be vids of some street runs (closed course of course )
glad to help out a fellow slobalt owner
Old 01-18-2011, 10:56 AM
superbug's Avatar
The "hard way" was me having to contact ZEX to find out why the kit wasn't working (and it took them a quite a while to figure it out) then me having to find a proper resistor...for some reason no one carries resistors in my town :p. Got it working an hour before race time
Old 04-27-2011, 11:22 AM
danielhubbard2001's Avatar
I have a Nos sniper system and I'm hooking up to the TPS, so I need to tap into the purple wire?? And do I need a resistor or not???? Please help trying to get this hooked up today. Thanks.
Old 04-29-2011, 06:03 AM
BlkWdoSS's Avatar
yes, tap the purple wire and I havent used that particular kit, but I would add a resistor it will definitely keep you from possibly burning up the circuits, wiring, or other pieces.
l8r,
PD
Old 04-29-2011, 09:39 AM
l8r,
PD
Thanks for your help, I'll let you know how it goes.
Quick Reply: Installing Zex Kit
