Japeatr's Nitrous Express Installation
thanks... been traveling for work and havent had much time until this weekend.
heres whats left.
-terminate 2 power wires to fuse box
-mount and wire 4 switches
-run wires for bottle heater and bottle opener to bottle from switches
-install grommet for nitrous line and blowdown tube
heres whats left.
Could you please post a link or photo of where you hooked up the wires for the window switch? I am going squeeze the motor for a while till the second block for the turbo set up is built and way i was going to set up my nitrous was a button for the spray away from the shifter so i would have to stop spraying to shift. That way i couldnt have a chance on spraying during shifts.
#40
Trifecta does have the No2 algorithm in it and acts just like GMstg3. The extra benefit with Trifecta though is that all the tunes are adjustable, meaning Trifecta can adjust for any amount of shot and can pull "x" amount of timing as needed.
