Nitrous Oxide N20
Spinning when spraying?
Old 10-30-2008, 10:09 AM
SSdan's Avatar
What is the general consensus to this? Let off to stop spinning or stay on it and shift to the next gear?
Old 10-30-2008, 10:14 AM
JPizzle's Avatar
Automatic or Manual?
If in a manual, you do not want to change gears while your tires are spinning, because it leads to premature wear on the clutch & supporting parts.
BTW, what trim is this for?
Old 10-30-2008, 11:51 AM
SSdan's Avatar
SC.
I spin them just punching it in 2nd, tires start to catch about 6200-6500 and then I keep on going into 3rd
Old 10-30-2008, 11:54 AM
originaladrian's Avatar
in general no.... when u spin the tires ur not going anywhere. traction FTMFW
im going to say let up a bit then punch it
Last edited by originaladrian; 10-30-2008 at 11:54 AM. Reason: Automerged Doublepost
Old 10-30-2008, 11:57 AM
SSdan's Avatar
Here's the thing, nitrous is either on or off.
Old 10-30-2008, 12:28 PM
WOT switch?
Old 10-30-2008, 12:30 PM
dedecv3's Avatar
Old 10-30-2008, 12:52 PM
IonNinja's Avatar
when I figure it out I'll let you know
I havent' been able to net anything better than a 2.4 60' at the track
but yes the whole on/off thing doesn't help at all...
Old 10-30-2008, 02:58 PM
SSdan's Avatar
Originally Posted by originaladrian
WOT switch?
That and nitrous gets ugly when you are on/off very rapidly.
I'm just curious if letting the tires spin while spraying is a bad idea.
Old 10-30-2008, 03:01 PM
04redline0124's Avatar
SC.
get godo tires then...I had more power then around 95 percent of ppl on this forum, and never had a problem with 2nd gear, you guys are doing something wrong. Get KDW's and call it a ******* day
Old 10-30-2008, 03:27 PM
SSdan's Avatar
That's my next motive.
I have some nice kumhos for when it's warm, but this winter is kicking my ass.
Don't forget the ground gets mighty cold where I'm at in jersey, aint warm like Florida.
Old 10-30-2008, 03:31 PM
Tazmanian_Dvl's Avatar
If you're spinning then you're not going anywhere. If you have an SS/SC I wouldn't turn the spray on until maybe half way through 2nd or maybe even wait until you shift into 3rd. If you flip the switch and all you do is spin then it's not helping you at all. Using spray in 1st is completely pointless and I"m thinking 2nd would be pretty pointless as well... Jusy my $.02
Old 10-30-2008, 03:32 PM
get some tires and it wont be so pointless trust me lol
Old 10-30-2008, 03:35 PM
1st gear is useless on the SS/SC's it's too short and if you punch it all you do is spin. I don't think anything but slicks would help us there...
Old 10-30-2008, 03:37 PM
D4u2s0t's Avatar
if you're spinning completely through 2nd you probably shouldn't be using your nitrous in 2nd. problem solved :
Old 10-30-2008, 03:38 PM
That's what I said. Personally if I was a bottle baby I wouldn't be turning it on until I hit 3rd...
Old 10-30-2008, 03:40 PM
im talking about 2nd gear lol....and wtf we have a first gear?
All im saying is that when I had clutch bottle heater and my 90 shotin the carpl us alot of other goodies the car made prolly near like 330ish whp and I had no problem with 2nd gear, it hooked very nicely becuase I ad GOOD tires on the front lol
Old 10-30-2008, 03:51 PM
SSdan's Avatar
In the summer.
Before the nitrous came out the car it wouldn't spin at all in 2nd.
I'm worried about the winter.
Old 10-30-2008, 10:26 PM
SSdan's Avatar
bump anyone else
Old 10-30-2008, 10:31 PM
slowswap's Avatar
Spinning and spraying won't hurt anything. Bouncing off of rev limiter well spraying is a huge no no.
Old 11-03-2008, 04:34 PM
1^up's Avatar
dan in the winter you can't spray if your on all season tires or junky tires. where we live you will not get traction. if you don't want to spin you will have to do a 60mph roll. if the bottle temp is past 900psi in 2nd gear you are going to spin. if you don't use a bottle warmer and run 600-700psi and have the heat on in the car lol you prob will not spin at 40mph in 2nd gear
Old 11-03-2008, 04:51 PM
SSdan's Avatar
I was hoping for input from you since you know the weather. I'm on summer only tires and they spin in the cold right now slightly until 60 or so. I was wondering if it'll do any damage to the car.
I got a bottle warmer now too so you can bet I'll be pushing it at 950psi all day long.
Old 11-03-2008, 04:54 PM
1^up's Avatar
how is it holding up (the engine and all)? what fuel jet are you running? did you up it so it is safer or are you running a custom tune?
if the bottle temp is low you will not be running the full shot but you will not spin. not spinning is better than spinning. my recommendation for you if you can warm up the tires and once it is warm again i believe the best tires we can get are kdw2's.
you should come up and let me fill up your bottle and run me for fun again. i got my bottle warmer hooked up now too.
also i ran 13.4 @ 107 with these all season tires i am running that are junky. that was w/o the bottle warmer and i had the pressure gauge on and i was at 700psi bottle temp or so. plan on going back once more this season, would you want to come to watch or video tape or run your car for fun?
Old 11-03-2008, 05:01 PM
SSdan's Avatar
I tuned it now and I got a permit as well. The jets are staying the same, I'm just gonna play with the bottle pressure to see what I like better.
Old 11-03-2008, 05:03 PM
1^up's Avatar
i edited my last post if you can read it and add if you would want to come to the track with me before this season is over. also who tuned your car? if you tuned it yourself would you mind tuning me and limiting my boost and also making the exhaust engine light turn off?
Quick Reply: Spinning when spraying?
