Nitrous Oxide N20
Spray on a stock 2.2
Old 06-21-2013, 02:08 PM
rawdog's Avatar
Has it been done, effectively and efficitiebtly ?
Old 06-21-2013, 02:11 PM
Incognito11's Avatar
^ is that word supposed to be efficiently?
Also are you truly asking on a totally stock 2.2? if so then the answer is no
Old 06-21-2013, 02:16 PM
tamadrummer's Avatar
Did you know that most modern browsers have spell check built right in! RED SQUIGGLY LINES, BRO!
But spray on a stock motor sounds like BOOM.
...or do it and post videos.
Old 06-21-2013, 02:17 PM
Twoozofjuice's Avatar
I know a guy that was using spray on stock motor 2.2 cavi or something like that
Old 06-21-2013, 02:59 PM
chevygirl2006's Avatar
I've seen one on YouTube blow up at the drag strip
Old 06-21-2013, 03:09 PM
wayfarer's Avatar
whatever power level your stock engine can handle-- it can handle on nitrous.
If your head gasket, pistons, rods, rings, etc can handle a 50 hp increase from a built motor, or from boost, it can handle it from nitrous
HOWEVER
you MUST insure that your tune is appropriate to your shot. Generically speaking; small shots are fine with relatively stock tunes. Advanced timing is generally not recommended. Reducing timing 1.5 to 2 degrees per 50hp increase is kind of the rule of thumb
after that, engage ONLY at WOT, and above 2500rpm
lots of safety features out there-- fuel pressure safety switches, nitrous pressure safety switches,
Old 12-31-2013, 04:25 PM
Tha Cavi Kid's Avatar
I sprayed my 2.2 eco 04 cavi with a 75 shot for 2 summers with bottles ( about 3-5 a weekend ) through it. Never Once having an issues due to nitrous. I made ssure to have the right rating for fuel (prem) and checked and replaced 1-2 step colder plugs on a regular basis and also depending on the weather and temps. I would never of sprayed more then 75 on a stock short block. The built motor we did for a friend had a 2 stage system with 150 total hp shot till he got a supercharger set up.
It can be done and safely, but it will help to buy the proper upgrades to the system like a window switch, bottle heater to keep temps up and to watch bottle pressure like a hawk.
Old 04-08-2014, 09:18 AM
DCsnow1000's Avatar
I've sprayed my 04 Cavi 2.2 with a stock bottom end and trans with a 75. never ran into issues and I was mean to it for the first couple weeks.
Lucky or Pioneer....who knows.
As I always say with anything that increases power, go for it...why not, just dont cry when something breaks. embrace the fact that **** happens and modding becomes a lot less stressful and more fun.
Old 09-07-2016, 05:28 PM
08_Slowbalt's Avatar
HOWEVER
I love this. Nitrous does not blow up motors, People blow up motors. I m carefully planning to spray the crap out of my 2.2L. Key words are carefully planning. A properly set up nitrous kit is no more dangerous than proper turbo set up.
Old 09-08-2016, 12:59 PM
exiged's Avatar
When I had a 2.2 it was on the bottle. Unfortunately, I had issues with it, and went through several intake manifolds. I'm not sure if it was the positioning of the nozzles (they were installed in the intake prior to the throttle body) or what but it kept blowing the manifold. Kind of turned me off to it frankly. I had a bottle heater and always made sure to use it above 3k RPMs too.
Old 10-05-2016, 03:40 AM
V8THIS's Avatar
i ran 100's of bottles thru one of my cavaliers that i swapped a 2.2 into, dont go over 75 shot. Im a nitrous express dealer if you want i can set you up with everything youll need to do it safely.
Old 10-07-2016, 06:10 PM
AlCFarrow's Avatar
Do you mind posting or sending me a list of everything I would need to run a 75-Shot nitrous setup?
Supercharged06SS
12-11-2022 04:47 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
dennis69
10-20-2015 04:49 PM
10-13-2015 09:32 PM
Stuff
10-01-2015 05:47 PM
Quick Reply: Spray on a stock 2.2
