Nitrous Oxide N20
Supply Line
Old 05-14-2011, 10:17 PM
shadowfaxss's Avatar
Supply Line
Debating the supply line install. Those of you that have the install did you run the line out the trunk and under car or through the inside with an exit in the engine bay? Installation feedback would be appreciated.
Old 05-15-2011, 11:25 AM
batboy's Avatar
I don't have nitrous on my Cobalt, but I do have it on my GTO. The feed line can be installed either way. I ran it hidden through the interior of my GTO, but some of my buddies ran it outside underneath the car. Just make sure it's securely ziptied up out of the way and that it don't rub on suspension parts. If you go through the interior, it should be a single line with no connectors (potential leak points).
Old 05-16-2011, 10:49 PM
Wow.....no one with a cobalt and nitrous have some input on the supply line installation?
Old 05-16-2011, 10:51 PM
I'm too JDM for you
BLAZIN07SS's Avatar
my bottle was installed behind the passenger seat. ran the line through the interior. worked great for 2 years
Old 05-16-2011, 10:53 PM
LS6Rally's Avatar
i Dont have Nitrous, But i would run it inside the car. Shouldn't be any issues, like stated above, use a one piece line.
Old 06-16-2011, 09:01 AM
Moderator Alumni
zinner's Avatar
I had it in my cobalt. I drilled a hole on the upper side of the spare wheel well. I then ran it along side the fuel lines into the engine bay. Had it there several years no issues. Not sure you want to run it inside just in case it burst or leaked.
I also put some rubber bushing in the hole so it wouldn't chafe the nitrous line. Never had any issue with water or the elements getting in there.
Old 06-16-2011, 09:20 PM
Thanks. Much appreciated. Running outside is the decision I made and will begin final installation this weekend. I spent some time researching grommets for sealing the line.
DarrenGC
12-24-2021 01:55 PM
RaginChopsuey
10-27-2015 01:27 PM
SlowSaturn
09-28-2015 11:03 AM
Extreme Dimensions
09-24-2015 07:51 PM
Cobe
09-19-2015 11:04 AM
Quick Reply: Supply Line
