Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums
Go Back   Cobalt SS Network > Specific Technical Discussion > Nitrous Oxide
Nitrous Oxide N20
Want to install n2o
This is a discussion on Want to install n2o within the Nitrous Oxide forums, part of the Specific Technical Discussion category; I have a 05 cobalt ss/sc and want to install n2o, but dont know what to go with. The mods ...
LinkBack Thread Tools Search this Thread Display Modes
Old 07-30-2009, 10:20 AM   #1
Member #: 29341
Check out my gallery  Check out my vbgarage
Question Want to install n2o
I have a 05 cobalt ss/sc and want to install n2o, but dont know what to go with. The mods i have are gm stage 2, cai, full exhaust, stage 2 clutch, and 8lb flywheel. Do i go dry or wet shot? Wjat shot should i use? Can you please give me some suggestions and reccomendations on what to go with. And what i need to do if i install n2o.
__________________
I don't know what screams louder you girlfriend or my supercharger. COBALT SS STAGE WTF!!!!!!
roser4888 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 07-30-2009, 10:22 AM   #2
Member #: 26037
go with a wet shot for sure. and to start off i would go with a 35 shot and that will give you about 50 whp gain. but i would tune for it for sure.
__________________
tvs supercharger,2.9 pulley, 79 lb injectors,rebel 3" intake, ls4 tb,cti header,cti catless 3" dp,cti 3 " catback,cx racing heat exchanger,ott billet stg 2 rotated mounts,meth injection, spec stg 3 plus clutch,spec flywheel,dss stg 2 axles.this winter fully cnc intake and ott return style fuel system
scott allen is offline
Old 07-30-2009, 10:49 AM   #3
Member #: 29341
Is the gm tune ok or i need a different tune? I cant find anyone near me that does a tune on my car.
__________________
Old 07-30-2009, 11:12 AM   #4
Member #: 30413
do you have a wideband?
daythecountrydied21 is offline
Old 07-30-2009, 11:12 AM   #5
Member #: 30413
Old 07-30-2009, 11:34 AM   #6
Member #: 29341
No im prob gonna get one
__________________
Old 07-30-2009, 12:56 PM   #7
Member #: 26037
i would get tuned.
__________________
Old 07-30-2009, 04:29 PM   #8
Member #: 8592
Not to call anyone a liar, but the GM stage 2 tune goes great with a 50 wet shot. I personaly have been running the stage 2 tune and a 50 shot for nearly a year now and have not had one problem. Just make sure you do it right and not half ass and you should be fine.
__________________
StreetLC is offline
Old 07-30-2009, 04:36 PM   #9
Member #: 26100
how so?
__________________
Too Much...
"I know you saw me bitch"
Cefaln452 is offline
Old 07-30-2009, 05:31 PM   #10
Member #: 18847
Quote:
Really? What would you say about a wet 75? And what exactly are your mods?
__________________
[SIGPIC][/SIGPIC]
June 2009 COTM
ChriSS/SC is offline
Old 07-30-2009, 05:37 PM   #11
Member #: 3956
Stage 2 tune, don't exceed a 50 shot. Especially if you are running a smaller pulley on the stage 2 tune.
Obviously, tuning for the nitrous is the best option, but you can run it untuned if you keep the shot small and the boost reasonable. I've seen a 90 shot on a 2.9" pulley done safely with tuning, and a 75 shot on regular stage 2 pulley with no tune, but a 75 shot on stage 2/2.8" has cracked pistons in more than one car I know off, along with a 100 shot untuned on a stock car.
__________________
ItalianJoe1 is offline
Old 07-30-2009, 05:41 PM   #12
Member #: 17140
I just hooked the bottle directly to my intake manifold and floor it around. Works great!
__________________
chris88z24 is offline
Old 07-30-2009, 05:44 PM   #13
Member #: 29674
Quote:
lol i like this approach
__________________
TVS
06_SIC_SS is offline
Old 07-30-2009, 05:46 PM   #14
I'm too JDM for you
BLAZIN07SS's Avatar
Member #: 17170
i was on stage 2 w/ 2.9 pulley, full bolt-ons and 60 shot forever. ran 20 bottles of nitrous through the car like that
__________________
STANCE CREW MEMBER #001 JDM CREW MEMBER #001
http://i50.tinypic.com/2e3vae0.jpg
BLAZIN07SS is offline
Old 07-30-2009, 05:49 PM   #15
Member #: 20389
i still would like to see someone run a 50 on a 2.7 with supporting mods. I bet that bitch would haul
__________________
2007 SS/SC G85 (Modified Stock M62) - 13.1@107mph -Street tires- (before meth and retune) Meth injected
zrated89 is offline
Old 07-30-2009, 05:51 PM   #16
Member #: 3956
Quote:
I did it on a 2.8" with a little more than a 50. It was fast.
__________________
Old 07-30-2009, 05:55 PM   #17
Member #: 20389
i plan on getting ottps dyno tune kit and running a 50 on my 2.7. cars makes awesome power now and pulls hard. Im on a custom tune i have a wideband already and an aeroforce. Im just wondering how much timing im running at WOT. I think what ima do is run it see what my AFR's are and see if im getting any KR on the aeroforce.
Quote:
and was that the setup you cracked you piston on? but you spun then hooked and bogged correct? Also how muchboost were you seeing on just the 2.8? Ive seen 19.2 at WOT in the top of third at the track
__________________
zrated89 is offline
Old 07-30-2009, 07:01 PM   #18
Member #: 8592
Quote:
Prety much same mods as me.....Its a winning combonation
__________________
StreetLC is offline
Old 07-30-2009, 07:19 PM   #19
Member #: 26100
how do are blown motors like n2o?
__________________
Too Much...
Old 07-30-2009, 08:52 PM   #20
Member #: 3956
Correct, I was also running full stage 2 timing when that happened, which I shouldn't have been. I didn't have access to my HPT for a couple months to back it back down after some diagnostic checks, and it cost me a motor.
I was about 17-18 psi tops, I had some pretty decent port work and full cooling done though.
Quote:
Originally Posted by Cefaln452 View Post
how do our blown motors like n2o?
Boost + nitrous is a winner, every time. It has a superior intercooling effect, as the nitrous is something like -150 degrees when it hits the air stream. On our cars, with such poor compressor efficency, the gains from the added cooling make for a much better power gain from a given shot size, although that gain doesn't really increase as shot size climbs. Assume a '50' shot gives you 65whp gain, a '75' shot will gain about 85whp, not 100.
__________________
Old 07-30-2009, 08:56 PM   #21
Member #: 26100
say im running a 2.6... would that be too much boost to add n2o also
__________________
Too Much...
Old 07-30-2009, 08:57 PM   #22
Member #: 26100
__________________
Too Much...
Old 07-30-2009, 09:03 PM   #23
Member #: 3956
It's never too much boost, but at a certain point you start to have to trade off more timing to run the larger shots than the extra power is worth. Start with a smallish, 30hp shot or so, tune accordingly. If everything is manageable, bump it up one or two jet sizes at a time, re-tune for it, and stop when you are having trouble finding traction in 3rd or you stop gaining power.
__________________
Old 09-06-2009, 12:53 PM   #24
Member #: 29653
wet is defently the safest. always start 35 work your way up check plugs and codes. alot of ppl rut 50 wet
__________________
NOScoby
17" rims, wet nitrous, custom slam bags air ride, k&n, ported intake, custom exhaust with thrush 2chamber 2.25muffler, black emblems/grill delete,grandprix spoiler, led tailights, 8500k super purple headlights, eyelid and window eyebrow,racing seats and wheel and more
noscoby is offline
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
