Any one in Delaware out there
Old 04-11-2011, 09:55 AM
  #25076
BlackCobalt707's Avatar
any finished pictures, joe?
Old 04-11-2011, 09:58 AM
  #25077
CudaJoe's Avatar
Originally Posted by rallycobalt06
that subie is all kinds of fail........
Fail #1: it's an 08
Fail #2: he drag races it
Fail #3: FMIC on a stock turbo
Fail #4: horrible FMIC setup, the bumper will block most, if not all, the air flow to it.
Fail #1: it's an 08 - IT will rape an 09...
Fail #2: he drag races it - He raced it ONCE.
Fail #3: FMIC on a stock turbo - New g20 in the mail, new injectors in the mail, bigger fuel pump already installed.
Fail #4: horrible FMIC setup, the bumper will block most, if not all, the air flow to it. - Grill is cut out.. FMIC is fully visible.
psi is pressure..... putting a bigger fmic will release some of the pressure, hence the drop in psi. i bet it's a tad bit laggy now too.
pics of completion..... now.
No pics yet, lol. Hes gotta data log it and finish the dremeling of the front bumper so it looks clean and not a hack job, lol.
Yeah, it released alot more pressure than I thought it would.. watching the fuel trims on his tuner software I notice the car runs real rich at intial throttle and tapers back 0.0%... I expected that so it needs to be tuned out. He also needs to play with his Perrin BPV to adjust the spring pressure... had a tad bit of surge.
The turbo lag is not really noticeable with this setup.
  #25078
rallycobalt06's Avatar
Originally Posted by CudaJoe
That fmic comes with a new crash bar though it may not be as BIG as the stocker is certainly feels as strong. THe IC is bolted to it on top. Its the thin bar going across. It is made of two hollow tubes welded together and bolts to the factory crash bar mounts. I dont think its that big of a deal since the IC was never there in the first place and can also participate as a crashbar
The funny thing is he is on the stock TD04 and his turbo used to make 17.5psi with the stock tmic, but it makes only 15psi at the most with this one.. lol. He might be able to tune it back to 17.5psi but I doubt it. He's still making the same power at a lower psi now.
ITs nOT upside down! I promise. charge pipes were a bitch but if it was the other way the cp's wouldnt even work, lol. Had to cut a huge chunk out of the bumper and remove his coolant tank. Replaced it with a smaller coolant tank...
Old 04-11-2011, 10:14 AM
  #25079
ross talks so much ****. its funny havin him on my facebook. im half considering taking a trip to florida when i get my turbo swap and rape his car and visit some other people for the forums possibly
Old 04-11-2011, 10:15 AM
  #25080
CudaJoe's Avatar
Just got a message from him saying the coolant cover popped off.... the new tank used the factory cap. I know he didn't have much coolant to begin with either... he bought a knock off turbo xs. Some fabrication required
  #25081
i got a knock off turbo xs bov....and i got a authentic one.....the knock off one actually works fine
Old 04-11-2011, 10:20 AM
  #25082
Tarheel62592's Avatar
thinking about going lower...what springs are lower than sportlines?
Old 04-11-2011, 10:25 AM
  #25083
i think SSC springs go a bit lower. get some Megan Racing coilovers, they're inexpensive, decent quality and will get you the low you want.
Old 04-11-2011, 10:26 AM
  #25084
CudaJoe's Avatar
well yeah, The whole IC kit is a knock off Turbo XS. SOOOo many fitment issues. Nothing a hammer and a piece of cardboard couldnt fix though
Old 04-11-2011, 10:31 AM
  #25085
i like real stuff that is direct bolt on
i'm trying to decide if i want to sell the magnaflow catback or have it modified...... hmmmmm
Old 04-11-2011, 11:06 AM
  #25086
Modify it! and never heard of the megan racing coil overs, ill look into that
Old 04-11-2011, 11:11 AM
  #25087
because i'm lowered and have the rotated tranny mounts on..... the exhaust is all jacked up and doesn't fit like it should. so when i have a resonator added to kill the drone i'll have them adjust the way it hangs in the exhaust tunnel and over the axel and the in the bumper cutout.
Old 04-11-2011, 11:30 AM
  #25088
CudaJoe's Avatar
yiou want to see what it looks like? here's an IDea, We followed this DIY when installing it... .kinda...
2008-2010 TurboXS FMIC Install Guide - NASIOC
car looks like its smiling with braces... thank God he got a black IC.
Old 04-11-2011, 11:35 AM
  #25089
can't see the pics here at work..... oh well.
Old 04-11-2011, 11:51 AM
  #25090
wantedSS/TC's Avatar
ahh dururrrr
Old 04-11-2011, 12:48 PM
  #25091
CudaJoe's Avatar
sigh.... anyone know where you can find a coolant overflow tank cap?
Pretty big ******* problem with doing these front mount swaps is they make you reuse the factory cap.... problem is they pop off while your driving.... and they dont sell and after market cap...
Old 04-11-2011, 01:27 PM
  #25092
duct tape
Old 04-11-2011, 01:34 PM
  #25093
did you guess touch anything with the coolant system?
  #25094
CudaJoe's Avatar
thats what I told him for a temporary fix. what a nightmare. shoulda done more research.
Old 04-11-2011, 01:52 PM
  #25095
CudaJoe's Avatar
yeah, replaced the coolant tank with their smaller one.. stock cap goes on it. problem is, it didnt stay. Who knows when it popped off and what road its on, lol
Old 04-11-2011, 01:53 PM
  #25096
BlackSS185's Avatar
i made my exhaust and i don't even have problems like that hahah plus your dp has a flex join i don't see how that or rotated trans mounts even effect you exhaust. the only issues Ive heard of is hitting the rear axle but that can be fixed with an extra hanger..
ps : sounds like you didn't loose fit everything before tighten it all up lol
Old 04-11-2011, 02:13 PM
  #25097
sounds like your a ********!
it's hitting in the exhaust tunnel under the car, the over axle section isn't being held up high enough (hitting the axle) and the muffler isn't sitting right in the bumper.
if YOU can do welding, pipe bending, etc..... we need to talk.
Old 04-12-2011, 10:58 AM
  #25098
whatsup everyone?
Old 04-12-2011, 11:14 AM
  #25099
my damn mouth is numb...this sucks
Old 04-12-2011, 11:16 AM
  #25100
my body hurts lol
Quick Reply: Any one in Delaware out there
