Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
OTTP stage 1 h/e
Old 01-29-2014, 09:28 AM
Administrator
Administrator
Staged07SS's Avatar
I found the thread but it doesnt have the diagram I need lol. which is fine because itilianjoe pretty much explained how to run the setup for the h/e and option b setup w.o the dual pass.
Opt. B simply replaces the stock filler neck.
You follow the diagram I have posted for no dual pass, and simply remove the stock filler neck and replace with opt B.
Also, I'm pretty sure I explain how to bleed opt b. in that thread along with my dual pass install thread. You just need to read them a bit.
Staged07SS is offline
Old 01-29-2014, 09:30 AM
06cobaltncng's Avatar
I only skimmed down about 8 comments lol. kids starting acting up so I stopped reading. ill go back to it.
06cobaltncng is offline
Old 01-29-2014, 09:31 AM
Administrator
Administrator
Staged07SS's Avatar
Yes, fully read through my threads man.
Things get updated an added all the time.
Old 01-29-2014, 09:35 AM
blueLNFftw's Avatar
If your option B does not bleed itself in then you did it wrong.
blueLNFftw is offline
Old 01-29-2014, 09:42 AM
blueLNFftw's Avatar
IIRC mine is stock end plate and...
pump out > stock HE > FMHE > laminova in > laminova out > back to pump in
Old 01-29-2014, 09:50 AM
Administrator
Administrator
Staged07SS's Avatar
You have to sometimes burp the opt b tank when you first install it.
I explain how to do this in many of my threads.
I've been running Opt. B for 6 years w/o issue.
Old 01-29-2014, 10:06 AM
Thats how mine is ran. which is basically this diagram.:
Old 01-29-2014, 10:07 AM
I bet my issue is that we ran/installed everything and then added coolant and turned the car on.
Old 01-29-2014, 10:21 AM
Administrator
Administrator
Staged07SS's Avatar
You have your lines a little outta order.
The 3/4" line from the option b tank should go into the top of the t fitting.
Old 01-29-2014, 10:24 AM
blueLNFftw's Avatar
This.
So that it "drops" into the system.
Old 01-29-2014, 10:29 AM
  #36
ohh..ya know I never even thought of that lol. we were thinking we had to take the hoses and damn near rearrange them like with a dual pass. ill go correct that.
Old 01-29-2014, 10:46 AM
  #37
yep just snapped that fitting like a damn toothpick lol.
Old 01-29-2014, 11:01 AM
  #38
blueLNFftw's Avatar
Go to Ace.
They usually have them with the barbs
Old 01-29-2014, 11:09 AM
  #39
the only issue is I cant get back up the hill on my road, thus why im not at work lol. oh well coolant didnt pour out of the lines like I thought it would.
Old 01-30-2014, 04:54 PM
  #40
alright got it replumbed now. lettting the coolant flow! waiting to see fluid from the small line going into the opt b tank.
Old 01-31-2014, 07:11 AM
  #41
Administrator
Administrator
Staged07SS's Avatar
Fluid should not run cont. through small line to opt b tank. It is not a flow through!!
The small line is the bleed line to release trapped air.
Old 01-31-2014, 07:21 AM
  #42
ohhhh so just the fact that coolant is bubbling from the 3/4 line means its working. side note: after the replumb I did a nice little pull, iats went from 110ish to 80 fairly quickly.
Old 01-31-2014, 07:56 AM
  #43
Administrator
Administrator
Staged07SS's Avatar
It's working.
Old 01-31-2014, 08:56 PM
  #44
thanks buddy. I hope one day my car is half as nice as yours :-)
Old 02-01-2014, 11:25 AM
  #45
Administrator
Administrator
Staged07SS's Avatar
Thanks man
If you ever need anything, feel free to PM me.
Old 02-01-2014, 11:28 AM
  #46
Thanks man
will do me amigo!
Old 02-02-2014, 12:49 PM
  #47
Jedi Master
Tsbbzm's Avatar
Got it installed in around 4 hours or so. Went pretty smooth minus fighting the hose clamps that were already on it.
Heres a much better picture of the product
Edit: Also did not remove front bumper. Used Staged07's How-to and everything went well
Tsbbzm is offline
Old 02-02-2014, 01:00 PM
  #48
lets see it on the car!!
Old 02-02-2014, 01:08 PM
  #49
Jedi Master
Tsbbzm's Avatar
One sec
Tsbbzm is offline
Old 02-02-2014, 01:19 PM
  #50
Jedi Master
Tsbbzm's Avatar
As requested
Tsbbzm is offline
Quick Reply: OTTP stage 1 h/e
