Climb's build (turbo l61)
#103
yes lsj hubs, calipers/brackets and rotors bolt right up, and if ur going 5 lug might as well go 5x114.3 redrilled hubs, and for rear you can bolt lsj hub on to the rear beam and use a a 5 lug drum, unless you want to go disk, swapping out complete rear beam is easiest
#105
#107
#112
well good news mongo is back from az, springs off to powdercoating so are front calipers, bad new starter went on my town car so i might have to hold off on getting mongo's parts till next week
#113
well i picked up parts from mongo last night!!!!
lsj rear axle beam
lsj rear calipers and brackets
lsj rear rotors redrilled to 114.3
lsj front rotors redrilled to 114.3
got the rear calipers tore apart for powder coating, now everything is off at powdercoat, might swap in the beam this weekend, need to order rear pads, and need e brakes cables, than wheels!!!!
fml lol all tore apart
fresh cut on rear rotors!!
base front rotor next to lsj front rotor
base front vs lsj rear!!! lol
lsj rear axle beam
#119
Your slobslts come along way bud keep up the good work and keep embarrassing those nismos also im pretty surprised your not trying to sell again lol its about that time of the month
#120
#124
well, got a little update, calipers are done, springs getting powdercoated today, hopefully have all that back tomorrow, got the rear beam installed, hubs on, brake lines made, tested the nismo wheel in the rear, let me just say i cant wait to get this thing done!!
picture from my powdercoater
test the front nismo wheel
18x9 +30 with a 235/40
id be happy with this height
than made it tuck lol
ss rear beam
new brake lines
old base model rear axle, came right out, had to cut one bracket bolt due to a caster nut spinning, but i am able to nut and bolt that one so no worries
she has rear disk!!
ss rear beam
new brake lines
she has rear disk!!
