CobaltSS 16 TVS Build Thread
#277
Thank you guys... appreciate it
BTW couldn't pull the fenders yesterday (unable too) so I'll be working a little magic in the rear hopefully sometime this week... hopefully fix my rubbing issues. Maybe ill make my way to an exhaust shop this week as well to get my new resonator ordered and installed. Getting tired of it rattling, especially when its cold starting. It is unfortunate cause it sounds $$$ at WOT.
#293
Updates: Just bought an OTTP RSFS ... went with the walbro pump
Also, I was looking at my resonator options... made a thread about the vibrant after measuring and speaking with some people it looks like it may not fit. Mr.Belvedere forgot to take his medicine yesterday and locked my thread for no reason. Strong management is strong.
https://www.cobaltss.net/forums/loun...1/#post7578376
Anyways... long story short - looked at the vibrant ultra quiet resonator, then a huge magna flow. Ended up getting my ZZP resonator warrantied so another one is coming my way. Guess I'll give them one more shot (supposedly the fixed some of the internal welds since my last one.) 4th times a charm
Will be doing a few things to the balt today. Off from work.
#296
productive day. successfully shimmed the rear hubs. **** i don't wanna do that again. Had to take off all the brake components and rear suspension out to get to the hubs. Needed to Grind the top of the caliper as well so the rotor could spring freely. Probably only at -2ish degree camber. Looks tight. Handling seems to improved as well on hard turns but I only was driving around for 5 minutes on my test drive so hard to tell right now.
Since my rear suspension was out I decided it was a good time to also make a top bracket for the rear springs since I took my perches out couple weeks ago. This little rubber piece replaced the perches. I just made it from some plastic **** I had laying around and they work mint. someone asked (maybe it was me lol) if you can take out the perches of the rear springs without worrying if they will pop out. Let me tell you they won't. I had to pry those motherfuckas out.
I was feeling a bit frisky and modified my fenders a touch... aka grinded some edges off on the underside
Finally no more rubbing. Tucking the stockers hard on all four corners.
ZZP resonator came in today... wtf got that in a day. Nice job zzp. Going to the gym now so maybe Ill put it on another day.
#298
and I'm like you... fenders got all types of **** going on lmao. Rolled, pulled, etc.... and then every couple of months ill get a grinder and have a little fun with it I Should be fine for good moving forward now, even with my varrstoens setup on.
