Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums
Go Back   Cobalt SS Network > General > Problems and Service
Problems and Service Do you have problems with your new 2.0, 2.2, or 2.4L? What kind of service did you have done?
p1128... wtf is it!! lol
This is a discussion on p1128... wtf is it!! lol within the Problems and Service forums, part of the General category; o man i havent posted in month or so feel good to be back lol... so anyway i got the ...
LinkBack Thread Tools Search this Thread Display Modes
Old 08-28-2007, 12:24 AM   #1
Member #: 7811
Send a message via AIM to 0redline6
Check out my gallery  Check out my vbgarage
o man i havent posted in month or so feel good to be back lol... so anyway i got the p1128 code and i went to look it up in like google an it came up like 1756978369675 diffrent terms... the one that showed the most was Upstream Heated O2 Sensors Swapped... well like what can i do to fix that? and the car is running fine an all so idk... just wonderinggg thanks guys!
sooooo 14 looks an no answers.... COME ON!!!!!!!!! plz i wanna know if its life threating lol... even tho it didnt put the CEL on... i think my cat shit the bed that could be it right??
__________________
2006 Silver ION Redline... SOLD!!!
2009 Black Mustang GT
0redline6 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 08-28-2007, 08:58 AM   #2
Member #: 7811
Anyone!??!!??!?
__________________
Old 08-28-2007, 09:17 AM   #3
Edubs's Avatar
Member #: 6998
Are you sure it's P1128? That doesn't come up in the DTC list I have. Are you sure it isn't P1182:
Supercharger Inlet Pressure Sensor Performance
Check it again...
Edubs is offline
Old 08-28-2007, 09:22 AM   #4
Member #: 7811
i will run out an check it now..
ok so im a fuckin moron lol.. its p1182... im dyslexic sorry lol... an that doesnt sound good... but my car is running fine an like i said the cel didnt come on i just happen to do my weekly scan with my interceptor
__________________
Old 08-28-2007, 09:45 AM   #5
Member #: 12771
DTC P1182
Circuit Description
Important: The following applies to the intake air flow system performance diagnostic that is used in this supercharged engine:
• When referring to the "intake manifold models", the plenum volume between the throttle body and the supercharger is considered to be the intake manifold.
• When referring to "engine pumping", the supercharger and the intercooler plenum are considered to be part of the engine.
• The manifold absolute pressure (MAP) sensor that resides in the engine intake manifold is used to adjust the engine air flow estimates to balance the air flow models.
The intake air flow system performance diagnostic provides the within-range rationality test for the mass air flow (MAF), the supercharger inlet pressure (SCIP), and the throttle position (TP) sensors. This is an explicit model-based diagnostic containing four separate models for the intake system.
• The throttle model describes the flow through the throttle body and is used to estimate the MAF through the throttle body as a function of barometric pressure (BARO), throttle position, intake air temperature (IAT), and estimated SCIP.
• The first intake manifold model describes the intake manifold and is used to estimate SCIP as a function of the MAF into the intake manifold from the throttle body and the MAF out of the intake manifold caused by engine pumping. The flow into the intake manifold from the throttle uses the MAF estimate calculated from the throttle model.
• The second intake manifold model is identical to the first intake manifold model except that the MAF sensor measurement is used instead of the throttle model estimate for the throttle air input.
• A fourth model is created from the combination and additional calculations of the throttle model and the first intake manifold model.
The estimates of the MAF, the SCIP, and the TP that are obtained from this system of models and calculations are then compared to the actual measured values from the MAF, the SCIP, and the TP sensors and to each other to determine the appropriate DTC to fail. The following table illustrates the possible failure combinations and the resulting DTC or DTCs.
Throttle Model
First Intake Manifold Model
Second Intake Manifold Model
Fourth Model
DTCs Passed
DTCs Failed
X
X
Pass
Pass
P0101
P0121
P1101
P1182
None
Pass
Pass
Failed
Pass
P0101
P0121
P1101
P1182
None
Failed
Pass
Failed
Pass
P0121
P1101
P1182
P0101
Pass
Failed
Failed
Pass
P0101
P0121
P1101
P01182
Failed
Failed
Failed
Pass
P0121
P1101
P0101
P1182
X
X
Pass
Failed
P0101
P1101
P1182
P0121
Pass
Pass
Failed
Failed
P0101
P0121
P1101
P1182
None
Failed
Pass
Failed
Failed
P0101
P0121
P1182
P1101
X
Failed
Failed
Failed
P0101
P0121
P1182
P1101
If the powertrain control module (PCM) detects that the actual measured air pressure from the SCIP sensor is not within range of the calculated air pressure for the SCIP sensor that is derived from the system of models, DTC P1182 sets.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P1182 Supercharger Inlet Pressure (SCIP) Sensor Performance
Conditions for Running the DTC
• DTCs P0120, P0121, P0220, P0506, P0507, P1183, P1184, P2135 are not set.
• The engine speed is between 400-6,400 RPM.
• The engine coolant temperature (ECT) is between 70-125°C (158-257°F).
• The IAT is between -7 to +125°C (+19 to +257°F).
• The change in the TP is less than 5 percent.
• The above enabling criteria must be stable for more than 5 seconds.
• DTC P1182 runs continuously when the above conditions are met.
Conditions for Setting the DTC
The PCM detects that the actual measured air pressure from the SCIP sensor is not within range of the calculated air pressure for the SCIP sensor that is derived from the system of models by more than 20 kPa for more than 0.5 second.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Powertrain Control Module (PCM) Connector End Views or Engine Controls Connector End Views
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Observe the DTC information with a scan tool
Are DTCs P0641, P2228, P2229 set?
Go to DTC P0641 , DTC P2228 , and DTC P2229
Go to Step 3
Important: The harness connectors for the following sensors are of the same configuration but are not interchangeable.
Turn OFF the ignition.
Review the engine controls schematics for the barometric pressure (BARO) sensor and for the supercharger inlet pressure (SCIP) sensor and note the circuit colors.
Inspect the wiring harness of the BARO sensor for the proper connection.
Inspect the wiring harness of the SCIP sensor for the proper connection.
Did you find and correct the condition?
Go to Step 18
Go to Step 4
Inspect for the following conditions:
• Disconnected, damaged, or incorrectly routed vacuum hoses
• A supercharger or engine vacuum leak
• A misaligned, loose, or damaged air intake duct
• Any objects blocking the air inlet probe of the mass air flow (MAF)/Intake air temperature (IAT) sensor
• Any contamination or debris on the sensing elements in the probe of the MAF/IAT sensor
• Any damage or fractures to the SCIP sensor housing
• A missing or damaged SCIP sensor seal
• Restrictions or debris in the SCIP sensor vacuum port
Go to Step 18
Go to Step 5
Inspect the throttle body and the throttle valve for the following conditions:
• Any damage
• Any restriction that could affect the air flow through it
• A vacuum leak at the throttle body
• Any missing parts
• A throttle valve that is not fully open when the accelerator pedal is fully depressed
Go to Step 18
Go to Step 6
Test for an intermittent and for a poor connection at the SCIP sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 18
Go to Step 7
Disconnect the SCIP sensor electrical connector.
Observe the SC Inlet Pressure Sensor parameter with a scan tool.
Is the SC Inlet Pressure Sensor parameter less than the specified value?
0.1 V
Go to Step 8
Go to Step 11
Turn ON the ignition, with the engine OFF.
Connect a test lamp between the 5-volt reference circuit of the SCIP sensor at the harness connector and a good ground.
Measure the voltage from the 5-volt reference circuit of the SCIP sensor to a good ground with a DMM.
Is the voltage within the specified range?
4.8-5.2 V
Go to Step 10
Go to Step 9
Is the voltage more than the specified value?
5.2 V
Go to Step 12
Go to Step 13
Important: All electrical components and accessories must be turned OFF.
Turn OFF the ignition for 90 seconds to allow the control modules to power down.
Measure the resistance from the low reference circuit of the SCIP sensor to a good ground with a DMM.
Is the resistance more than the specified value?
5 ohms
Go to Step 14
Go to Step 16
Test the SCIP sensor signal circuit between the powertrain control module (PCM) and the SCIP sensor for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 15
12
Test all branches of the 5-volt reference circuit that is shared with the SCIP sensor for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 15
13
Test the 5-volt reference circuit between the PCM and the SCIP sensor for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 15
14
Test the low reference circuit between the PCM and the SCIP sensor for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 15
Test for shorted terminals and for poor connections at the PCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 18
Go to Step 17
Replace the SCIP sensor. Refer to Manifold Absolute Pressure (MAP) Sensor Replacement .
Did you complete the replacement?
Go to Step 18
17
Replace the PCM. Refer to Control Module References for replacement, setup, and programming.
Go to Step 18
18
Clear the DTCs with a scan tool.
Turn OFF the ignition for 90 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the Conditions that you observed from the Freeze Frame/Failure Records.
Did the DTC fail this ignition?
Go to Step 2
Go to Step 19
19
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List - Vehicle
System OK
Document ID# 1589321
2006 Chevrolet Cobalt
blktrax is offline
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Made this Accord look retarded LoL Kibosh3 War Stories 4 08-27-2007 02:12 AM
That's right, I fucking win again! NJHK The Lounge 33 05-14-2007 02:55 AM
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
