07 lsj-t problems gen 3 build
Old 09-25-2015, 11:40 AM
Adiaz1ss's Avatar
Okay so ive been having this problem for about 2 weeks now. I start the car and idles for about 4 seconds then dies like if its choking/sputtering. i have checked fuses, fuel pressure, compression, fuel filter, spark plugs, vacuum leaks, maf, fuel pump, throttle body, map, and everything in between. Also if i start the car and give it gas it wont die on me but only as long as i give it gas. I can drive it around but i jave to constantly be giving it gas. What could it be? i cant figure it out. And i sure the tune is not the problem as its being tuned by alan. Any ideas or thoughts? Please let me knw:/
Old 09-25-2015, 11:49 AM
Got Bewst?
Bluelightning's Avatar
That's a tough answer with the info given. Throttle body perhaps.
Old 09-25-2015, 11:55 AM
Adiaz1ss's Avatar
I swapped out the throttle body 2 times with working ones from two cars. Im using an le5 2.4 throttle body on a saab manifold if that makes a difference. also swapped mafs and map sensors and still same problem. It doesnt even throw a code other than random misfire and ac pressure switch which i wired to monitor a/f ratio.
Old 09-26-2015, 12:58 PM
mrbelvedere's Avatar
vacuum leak
Old 09-26-2015, 11:51 PM
SPDDMN36's Avatar
What's your blow off valve spring rating? I would guess it's too soft and you're opening the spring at idle. I had a similar issue after swapping to turbo.
turbochargedss2012
09-20-2023 12:17 PM
05-28-2022 03:47 AM
yellow dragon
09-28-2015 09:49 PM
DocSvensk
09-27-2015 02:24 PM
09-26-2015 06:44 PM
Quick Reply: 07 lsj-t problems gen 3 build
