Intermittent turbo flutter
Old 07-02-2019, 06:37 PM
Eddy1634's Avatar
So lately my car will start fluttering when I let off the throttle. Doesn’t do it all the time it comes and goes, so it could be fluttering then a few minutes latter it’ll be back to its normal bpv woosh sound. Car also has no codes any ideas on what it could be
Old 07-02-2019, 06:46 PM
Normal
Old 07-02-2019, 07:51 PM
Eddy1634's Avatar
Originally Posted by ECaulk
Normal
How’s it’s normal? Has never done it before and when it does the car barely accelerates
Old 07-04-2019, 12:11 AM
cobaltss#01's Avatar
Does it do anything else you failed to mention in the first post?
Old 07-04-2019, 10:22 AM
Dutchman's Avatar
No CEL codes? Does the car go into limp mode or limited boost?
Old 07-04-2019, 11:10 AM
If you get flutter after letting off of part throttle it is normal. If it is fluttering when letting off from going WOT then the bypass valve isn't opening completely and you need to check vacuum lines and boost control solenoids. It's not going to damage the turbo so don't put to much thought into it.
06cobaltss/ss
06-03-2018 06:37 AM
ATOMbomb
12-21-2014 02:04 PM
KoriCobalt
01-19-2014 07:30 PM
tomj77
11-26-2012 10:38 AM
TX.SS.TC
04-15-2012 11:45 PM
Quick Reply: Intermittent turbo flutter
