Engine cooling fan not running?
Old 07-02-2019, 01:49 PM
kelemvor's Avatar
Howdy,
Summer finally arrived here in WI and I noticed the other day that when I'm driving, my car temp shows the mid-upper 190s which seems normal. However, when I stop, the temp climbs up to the 210+ range. Once I start driving again, it comes back down to the normal area. I'm guessing that there's no fan that's blowing air to keep things cool. I'm assuming there's a fan somewhere but that maybe it's not running?
If anyone can direct me as to where the fan is and how to figure out what might be wrong, that'd be great.
Thanks.
Old 07-02-2019, 02:48 PM
exninja's Avatar
There's a simple way to see if the fan runs, open the hood and see. Which cobalt do you own? A base model Cobalt won't turn the fans on till over 215°F, so it may be working correctly. If there's no fan above 225°F, then you have an issue. Also, the A/C will turn on at least one of the fans (maybe both?) regardless of the coolant temperature.
jdbaugh1 (07-03-2019)
Old 07-02-2019, 03:37 PM
kelemvor's Avatar
I have a 2006 LTZ. I can try turning on the air and see if the fan starts up. If it isn't supposed to run until 225 then maybe everything is OK.
Old 07-02-2019, 03:56 PM
exninja's Avatar
Yeah, there's always quite a bit of worry with these cars regarding coolant temps. It's good to remember that the analog gauge on most "normal" cars will stay pegged in the middle even if the coolant temp moves 30°. There's no concern till it gets to 240°F.
Old 07-02-2019, 05:08 PM
kelemvor's Avatar
I'm looking at the digital readout on the information panel and I just watch it go up and down at times and didn't really know what's considered the Safe Zone and when I need to start to worry about something...
ThePie
01-29-2016 06:41 PM
Phil Pestowka
07-17-2009 11:55 AM
OrangeCrush
09-05-2008 01:49 PM
08sport
07-05-2008 09:08 PM
pykie
07-01-2008 10:02 PM
Quick Reply: Engine cooling fan not running?
