Battery Saver Mode
Battery Saver Mode
What the hell is this?
I went to get gas, and I left the acc power on. My radio and headlights were still on.
The DIC said "BATTRYSAVR" but nothing seemed different in the car itself.
Could my HID's be draining that much power, or is my battery shot?
Here's what was on,
Sirius radio unit (small, cheap, hard-wired)
radio
headlights/tailights
radar detector
I would say yer battery is toast.....i ran my stereo for 3 hours with the car off before i got the battery saver message so i thinks you need to be looking for a better battery than the stock POS.....Later
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to for load shed 2 setting criteria.
Load Shed 2 Start Less Than 10.9 V Battery has a net loss greater than 12 AH
Rear defrost, heated mirrors, heated seats cycled OFF for 50% of their cycle. The BATTERY SAVER ACTIVE message will be displayed on the DIC.
another dumb question, what's the warranty on our batteries?
Take it out and have it tested,If it comes out bad then Buy a new one .
But when you have 10v only, thats normally indicates a bad cell(2 volts per cell,6 x 2 = 12v)
Did you get the car started when in battery saver mode ,If so I guess the battery saver mode does work !
i just drove 4 hours last night rescuing somebody in the snowstorm on the thruway, and i was worried about my battery dieing when i stopped to get gas, but it worked
looks like i'm off to autozone for a free battery test
Stock batteries usually aren't the greatest. it is pretty typical to have to replace it after 3 - 5 years and occasionally sooner. I would just buy a new, good, battery.
You cannot add water to the battery it is sealed. Most car batteries now are all sealed and do not require adding water.
is there anything to gain from upgrading from our stock battery to a new one? I know if you are running a nice system in a car yes but otherwise what would be the benefit?
Sorry to bump and old thread, but I think this is what happened to my girlfriends '06 LT
(Keep in mind its original battery, MN weather)
We went to get gas and I left the car on ACC while I pumped the gas outside.
Went to go start it and I got the GM dead battery clicking noise.
Gauges went crazy, lights were flashing on the dash and radio. Headlights still had Hi and Low so I pondered about if the battery was really dead or not. After checking the cables in the back and at the alternator I tried it again, this time I turned off the lights and bam, car started.
A CEL came on for ECT low voltage imput and it stayed on for 2 days until it was cleared. While clearing it in the shop the "Battery Saver On" and "Check Charging Sys" went on.
Car cranks, but I question If the weather has taken its toll and now the battery is toast...
Hang on, I reccomend only ONE battery when people are requesting something better than stock.
It's not optima.
XS Power Batteries S3400 - XS Power Starting Batteries - Overview - SummitRacing.com
absorbed glass mat batteries are pretty much THE standard, since they don't allow for sulfation of the plates. I mean, eventually all batteries degrade so don't plan it as a do all end all, but I'm hear to tell you even optimas fail, the unfortunate thing is, most of the time an optima just suddenly has a dead cell for no explainable reason...but they do generally last 5-7 years at or near full capacity, not a miracle by any stretch since most interstate batts will do that too at half the price.
The big thing here is the battery is light as hell and cranks 2,000 amps.
It's not optima.
