Car wont start, security locked me out :(
Ok, so I drove out to my chicks place last night, had no problems.. never had any problems like this actually...
Finished the drive last night round 1137, came out this afternoon round 2, sat in my car an charged my phone for a lil bit while i checked some ****..
The car wasn't started, but thekey was turned one click past the acc spot.
I was sittin there for a lil bit, but not like an hour or nuthin. My phone had died so I was checkin my messages an voicemails an watever...
But i tried to start it, an the engine won't turn over. It just clicks a couple times from the engine and the security light flashes at the same time.
Then one by one all my systems start failing... abs, esc, air bags, traction, they jus start flashing on the dic
the security icon wasn't there until I tried to start my car if that helps...
I gotta be back home (2 hrs away) by tomorrow, this Chick flying out Monday an I'm not gonna spring for a hotel round here... they're fuckn expensive...lol
I called onstar an they didn't tell me anything I didn't know already.. bbut is basically have to wait until tomorrow an have my car towed to the local dealership
BUT I didn't do **** to turn on the security system, so is there somethin I can do to turn it off??
I haven't tried much yet, but it seems like my batterys dyin slowly 2
Helllppppppppp
Helllppppppppp
It jus recently started dyin... I can jump it, but that's not gonna do anything if the security system won't let me start it. My battery was fine until this whole security mess started :/ ima get a jump anyway tho so I can charge my phone lol
Security Relearn off zzp's website :
You can open and close the door- It doesn't matter. You will need to get in and out since you need to push in the clutch.
1. Depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
2. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
3. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
4. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
5. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
6. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
7. Turn the key off for 5 seconds, then depress the clutch and try to start the car. The car should start on this attempt.
NikkiVann (05-03-2022)
I'm tryin that relearn now, everywhere I looked, they all said somethin like that but everybody said the same ****... didnt work lol
I didn't jump it yet tho.... s no point till I can clear this
Nope, didn't work... after a while my lights started blinkin like I had my hazards on an the security light was blinkin along with em.. ima jus tow it to the dealership an talk wit em tomorrow
Resident Post Whore/Troll
**** happened to me in my ss/sc and it was my starter having a bad connection to the battery, fucked my car up, took over a month to figure out the problem and get it fixed, they replaced like $4k worth of stuff too, 3 batteries, 2 BCM's, 3 alternators and 2 starters
I got my car new back in august, its the same battery that came with it. I did try to jump it but to no avail...
It didn't even seem like it charged the battery any :/
it ended up bein my battery...
apparently I had already drained 2 cells in my 4 month old car, had it towed up to the dealership an they said that because my battery was dyin, the ecu activated the security system an locked me out. I couldnt jump the car or anything... All they did was put a new battery in... but it was a 7 hr process
I had left my car outside for 4-5 hrs? nuthin plugged in.. nuthin on... but the battery died.. uh huh... I think I jus got screwed over from when I had took it in before
Getaway_Driver
40
09-10-2015 09:11 AM
Getaway_Driver
09-08-2015 09:41 AM
brickloaf
09-06-2015 05:55 PM
