Check the bottom of your doors!!
Old 04-26-2009, 03:07 PM
  #51
ssyellow's Avatar
thanks a lot now I know where to look
yea I got a lil section of metal showing on the far left..I only got 17k miles so this prob is gona get worse
Old 04-26-2009, 04:14 PM
  #52
boostedss26's Avatar
Yes it is
Old 04-26-2009, 04:18 PM
  #53
eurochevy's Avatar
Originally Posted by boostedss26
wuuuuuuuuttttttt!!!!!!!!!...im checking mine when i get in today
Old 04-26-2009, 04:19 PM
  #54
I think i posted this theread a year ago and it's funny that people are now looking lol
Old 04-26-2009, 04:22 PM
  #55
eurochevy's Avatar
never even saw this a year ago
Old 04-26-2009, 04:25 PM
  #56
ssyellow's Avatar
well excuse me for joining recently....but in his case I see what you are saying. and I saw this when I joined and looked at my doors but was not sure where it was but thanks for pic
ooo he is a fast poster lol
Old 04-26-2009, 04:27 PM
  #57
lol i see it's a sticky now. Not sure what that means
Old 04-29-2009, 08:42 AM
  #58
metroplex's Avatar
FWIW I noticed the Cobalt chassis flexes very easily. I used the jacking points indicated in previous threads and had to open my passenger door with the rear in the air. I immediately noticed the door latch was hitting the striker at an odd angle. It was more difficult to close/open and I did not tilt the car at an angle. It was just lift in the air at the points right behind the forward trailing arm connections.
Old 04-29-2009, 05:14 PM
  #59
eurochevy's Avatar
ya just looked at my doors ..they starting to do this..not bare metal yet but close
Old 04-29-2009, 05:28 PM
  #60
watching
Old 04-29-2009, 10:49 PM
  #61
Not to sound like a dick but what does this have to do with GM putting little to no clear in our door jambs?
Old 04-30-2009, 04:56 AM
  #62
metroplex's Avatar
Well, what do you think is causing the doors to vibrate/rub against the weatherstriping so violently? The Cobalt is the first car I have seen where the chassis flexes enough that the paint rubs off the door or the door no longer closes properly when jacked using a unibody point.
Whether it has thick clearcoat has zero relationship with chassis flex/door wear. It would just wear through the clearcoat first. Like I said, when I lifted the car in accordance with the recommended jack points, the doors would no longer close properly.
I noticed the same wear pattern on my 09 SS/TC, and it came from the factory with 2 miles on the odometer. It is caused by rubbing against the weatherstriping when grit/dirt is trapped there. This is of course if you're referring to the photo of the yellow cobalt where the metal is rubbed bare. I used some leftover 40mil paint protection film (used for my X-Pel headlight film) and covered up that area. I would recommend keeping that weatherstriping clean though.
Old 05-02-2009, 06:42 PM
  #63
Their are alot of cars that flex like that, it rubs through from shutting the door, that is why it is worse on the driver side. And the fact that they put barley any clear on the jambs makes a big difference. I did mine a year and a half ago and it's perfect. "better than new"
As far as the weather stip keeping clean. I only drive my car in the summer and i wash it 3 times a week, it's kept spotless. Yes the yellow car is my wifes and i just redid her doors today. I did the same thing as mine, sand blasted the bottom, epoxy primed the bottom, seam sealed around the whole door and painted it. I also put the 3m chip gurd tape on the bottom edge.
Old 05-06-2009, 10:13 PM
  #64
Kolt's Avatar
**** i better check mine. ive got 1500 miles on mine (dont drive it much just yet) and yall who seen brand new 10 mile odo cars doing it has me worried. thanks for the thread whoever started it.
Old 05-07-2009, 07:44 AM
  #65
Your welcome
Old 05-07-2009, 09:22 AM
  #66
deerhuntr88's Avatar
Mine aint doin this, and I got almost 50k on it.... However, is anyone else's kickpanel getting all scratched up at the bottom?
Old 05-10-2009, 12:51 AM
  #67
Kolt's Avatar
**** mine isn't as bad as it could be but the pant is scratched to hell where its been im guessing flexing against the dirt and grime on the seal. got some silicon from work on it now. hopfully that will prolong the damage for some good miles.
Old 05-12-2009, 03:51 PM
  #68
Permafried-'s Avatar
This was never a problem on my 2.2, but checking last night my driver's side door is showing some marks in the same spot as the image. That said, my weather stripping is exceptionally dry so I'm going to be applying silicone imulsion to all my stripping tonight which I suspect will help the issue. I think when it gets hot the stripping simply sticks horribly to the paneling resulting in the damage we're seeing.
Old 05-12-2009, 07:30 PM
  #69
Kolt's Avatar
Yea i suppose its sticking but ive been watching it and dirt for some reason collects there in the corner between the seal and dorr for some reason on mine. prolly bc of my gravel drive.
Old 05-14-2009, 10:02 AM
  #70
I decided to check out where it was rubbing last night before applying the Emulsion to my weather stripping. It seems to me the rear corner of the bottom stipping is somewhat lacking in any form of support so there is potential for the door to rub constantly during normal driving. That said, I applied the AC Delco product to the stripping in my trunk, doors and sunroof so I'll keep an eye on it to see how it works out. First thing I noticed is that my sunroof has stopped crunching and cracking like it was before it was applied, the product was just tough to tell whether or not it was being soaked up by the weatherstripping or just hanging out on top. I'll keep an eye out (I cleaned off the residue from the door rub) and see if things improve.
As for the dirt collection it's because of where the stripping stops and there is still enough door gap for dirt to get in there during normal use, and living in on a gravel drive you're probably bringing in rocks with you that land in the door frame and eventually work their way towards the back. I can only imagine it making one hell of a mess of the paint if a pebble got in between the two on a long road trip .
Old 07-18-2009, 08:08 AM
  #71
Grey Ghost's Avatar
paint delamination
Originally Posted by Adirondack_Cobalt
I may as well **** on an electric fence for all its doing. The dealership told them that I have aftermarket wheels and tires (the tires are a 215-60-15... stock I think was 195? 205? 60-15) and the wheels are the same offset (?) as factory... I am getting the weenie.
They insist that those BF Goodrich tires are responsible... Maybe its just their paint is cheap, thin and falling off the car? Oh no, that can't be happening...
Scott
It's not like GM never had a paint issue on their 90's cars.
That's all I see around upstate NY...
but I guess they don't have factory tires either
Old 07-18-2009, 10:36 AM
  #72
^^ The paint isnt de laming
Old 07-26-2009, 07:00 PM
  #73
Adirondack_Cobalt's Avatar
so far, the condition inside the door jambs is not happening. My 2007 Cobalt SS/SC still has all of it's paint in the jambs and on the inside of the door. Not showing any sign of wear. Also, when jacked up (when I painted my calipers), i opened and closed the door with no issues.
Old 07-26-2009, 07:09 PM
  #74
redssna's Avatar
Mine is doing the same thing and nicely enough it's actually started to wrap around to the outside of the door. Car is long out of warranty though so i guess once it's mine i'm just gonna paint the whole thing. tons of stone chips all over the car anyway.
Old 08-05-2009, 12:23 AM
  #75
ipod's Avatar
mine is doing it to no surprise there lmao but my trunk also hits my bumper and scratching the paint off this while be 4 time goin in for that and the pasenger door three and i got 10k and its 7 mounths wtf
Quick Reply: Check the bottom of your doors!!
