help plz! power windows will not go up!
well I just got my car back from the paint shop, where they removed the doors and put them back, when I got the car the wondows were working great but later in the day the windows will not go up, I believe it is the switches because the lock and unlock switch is not working as well, I checked all connectors and they seem to be plugged in good, does anyone know what else I can check for this? both windows are not going up, where can I find the fuse for that?
All the fuses are located in the bcm for those things.
But if the connector for the driverside door switches inside the door isnt on properly nothing will work.
Did they have the doors apart.
Other wise I would say check the connector for the door just inside the car.Remove and reseaat it to be sure it connected properly.
thanks for your help guys but this is what is going on now, I checked some fuses inside the car behind the panel on the passenger side, there seems to be no power going to the fuse, so we ran a wired from from another fuse that was getting power and the windows worked fine, does anyone know why there is no power going to the place where the fuse is plugged in ?
The window fuse is feed from the RAP relay on the bcm its #32.
Pull it out and re seat it or you might need a new one but first make sure its being told to turn on.
It feeds power to alot of things from a main 50 amp fuse.
