Clicking noise in steering .. - Cobalt SS Network
Thread Tools Search this Thread
Old 05-27-2009, 08:10 PM   #1
When im stoped if I turn the wheel left and it makes a clicking noise ... any idea what it might be?
ziggity is offline   Reply With Quote
Old 05-27-2009, 08:58 PM   #2
Images: 35
You're sure it's not just the power steering kicking in since there's a large amount of play in the wheel when you're stopped that's essentially a deadzone? Just a thought.
Permafried- is offline   Reply With Quote
Old 05-27-2009, 10:59 PM   #3
Nah this is the first time it has ever done it.
Old 05-27-2009, 11:29 PM   #4
Images: 17
fyi our cars don't have power steering. we use an electric steering system. and the clicking is most likely your intermediate shaft
outtamymind is offline   Reply With Quote
Old 05-28-2009, 12:41 AM   #5
Quote:
Yeah, apparently the intermediate steering shaft on these cars is a ******* terrible design.
xxxxsh4d0wxxxx is offline   Reply With Quote
Old 05-28-2009, 03:01 AM   #6
Something that has to be fixed right away or get it fixed when I can?
Old 05-28-2009, 03:05 AM   #7
Doh
Quote:
It's probably moderately high on the priority list (correct me if i'm wrong)
I've had mine replaced two times in a year. And I swear it started doing it about an hour after it was replaced the second time. *This was like 6 months ago*
So i've just said **** it for now and i'll bring it back in when I have to for something else.
Doh is offline   Reply With Quote
Old 05-28-2009, 09:16 PM   #8
Images: 17
you can take your time but i would get it done sooner then later. and ya they are a horrible design for alot of gm vehicles not just the cobalts
Old 06-03-2009, 12:53 AM   #9
Is there any upgrade for that
nightridderSS is offline   Reply With Quote
Old 07-23-2009, 05:33 PM   #10
Brang it in a few weeks ago, getting a new steering column put in tomorrow.
Old 07-24-2009, 01:32 AM   #11
Images: 17
there is supposed to be an upgraded steering column, i apparently have it and i tell ya its not nearly as bad as the stock one.
Old 07-24-2009, 11:36 PM   #12
Yeah hopefully i get that then ... so I had an apointment at 8 and they call me at 4 and tell me they didnt get a chance to get in.. shitty service
Old 07-25-2009, 10:53 PM   #13
Images: 17
it happens. it happens at the shop i work at, and i'm busy all day and all the other techs work as much as they can, its the advisors that don't realize that they've overbooked.
Old 07-25-2009, 11:06 PM   #14
I know I already had it in last time though and they told me the same thing and now the same thing again and I had the apointment for about a month .. aww well ill get it done eventually ... little off topic but i seen in another thread you giving some advice on installing an intercepter ... whats the best way to do this? I should have mine this week and im not sure exactly how to install.
Old 07-25-2009, 11:30 PM   #15
Images: 17
well have you ever installed any basic aftermarket electronics such as a single led or a switch?
Old 07-25-2009, 11:34 PM   #16
Nope this is going to be my first mod on my car and this is my first car lol i seen some pics though doesn't look too hard and i'll get someone to give me a hand that knows more then I do but I was jw whats the best way to go ... just use the power wire from the stock boost gauge?
Old 07-25-2009, 11:37 PM   #17
Images: 17
no some people say its ok but those electrical systems are meant for whats on them and really not much more so i don't like doing that, rather i would go and get a mini make-a-fuse and use that to tap into a fuse slot that isn't in use. and use that to run your power wire. also since the interceptor comes with the jumper installed and is not needed for proper operation with the cobalts remove the jumper on the back of the gauge and thats really it. everything else is pretty straight forward.
Old 07-25-2009, 11:41 PM   #18
so just need the fuse and thats it? Certain slot?
Old 07-25-2009, 11:44 PM   #19
Images: 17
slot 22 should be empty with nothing on it. there is a diagram on the panel you remove to get to the bcm fuse panel
Old 07-25-2009, 11:46 PM   #20
Where at inside the car is the fuse panel?
Old 07-25-2009, 11:46 PM   #21
Images: 17
passenger foot well inside trim panel. there will be a little lightning bolt on it.
Old 07-25-2009, 11:49 PM   #22
But im not using my boost gauge anymore so would that matter? Wouldn't the power cable for that be sufficient?
Old 07-25-2009, 11:51 PM   #23
Images: 17
you could but like i said i don't recommend it.
Old 07-26-2009, 12:56 AM   #24
Ok thanks for everything , when I install it if I have any problems ill just post it back in this thread.
Old 07-26-2009, 02:33 AM   #25
Images: 17
sounds good to me
Thread Thread Starter Forum Replies Last Post
New steering rack Solaris99 08-10 SS Turbocharged General Discussion 27 08-31-2016 08:45 PM
Clicking Noise biniecki Problems/Service/Maintenance 8 10-25-2015 03:23 PM
Holy mother of torque steer TedSS 08-10 SS Turbocharged General Discussion 26 10-10-2015 05:30 PM
M62 help jimbofug007 Problems/Service/Maintenance 7 10-02-2015 01:06 PM
Hollow-Drone-Harmonic-noise coming from rear of vehicle driving me crazy DANRICKARD Problems/Service/Maintenance 8 10-01-2015 01:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
