cooling fans do NOT come on.
Old 01-21-2012, 08:52 PM
turbosmart4's Avatar
Unhappy cooling fans do NOT come on.
i am new here and decided to go Platinum to get the cool decals
my car's fans do not come on... the highest I've seen it rise is around 246 F without the fans coming on..... i remember they used to kick in around 196 F but now ...not even on LOW.... i found this out last month... the IC pump went out around the same time , so i started hitting it with a hammer to turn it on. i know i will replace it by next month (money issues) oh and i wired the left cooling fan (engine, not the ac cooling fan since it comes on when AC is on) so i can manually cool it down, but it still doesn't go as low as it used to. probably the IC pump isn't circulating well....i replaced the temp sensor already and the other one was checked for continuity and was still good ,but still replaced it...i also replaced both relays (fan1, fan2) ...i dont think it the thermostat since both lower and upper hose get hot... any ideas....? anyone?
Old 01-22-2012, 05:41 PM
insylem's Avatar
When the engine is hot, check the tempature of the radiator itself, if its not hot, then your thermostad is the problem.
Also check the fan fuses.
Also
What year/ Trim/ Engine?
With "Turbo" in your name Im GUESSing your SS 08/09/10 LNF
EDIT: Just checked your profile, your '06 LSJ
Old 01-22-2012, 06:35 PM
bratboy90's Avatar
Turn on AC, one fan should turn on immediately. If not, fan issue it is.
Old 01-22-2012, 06:53 PM
Also
The radiator gets hot and also both upper and lower hoses, so i dont think its the thermostat...
the fuses look ok.. this is driving me crazy.. i dont know where else to look i will re check everything again tomorrow, these cars only have 1 temp sensor right?
Old 01-22-2012, 06:56 PM
tried it... the fan comes on ... i have also tried disconnecting the temp sensor to see if it triggers the fans, and in 3 mins they come on
Old 01-22-2012, 07:35 PM
FryLoch's Avatar
I've said this before. The electric fan systems on these cars are terrible! I've never seen that high but I've 220+ many times in the summer. Really poor design. Fans are supposed to come on at 225, how stupid is that?! Normal operating temp is 180ish.
Old 01-22-2012, 07:39 PM
i wish my fans were just belt driven lol fans are pissin me off...
Old 01-22-2012, 07:40 PM
Blowncavy's Avatar
Turboed ss with an IC pump? Think not
Old 01-22-2012, 07:48 PM
its an lsj lol
Old 01-22-2012, 07:50 PM
nhanson's Avatar
When you get a tune have the fans set to 100% at 200*
Old 01-22-2012, 07:55 PM
smart move, but i think i wont tune soon (money issues and possible 2nd kid) lol but yea i think thats the best i can do....
Old 01-22-2012, 08:26 PM
RooTBeeR's Avatar
This has worked for me for a long time, never even gets to 200*F and struggles to get past 195
Old 01-22-2012, 08:32 PM
i wish mine did that..... i might do the same when i get a tune, so my computer is my problem??
Old 01-22-2012, 08:40 PM
nhanson's Avatar
i dont think so
Old 01-22-2012, 08:46 PM
to my understanding the temp sensor on left side of the engine sends a signal to the pcm and then the relays get signal and fans kick in... if the sensor and the relays are ok... what else can be wrong...?
Old 01-22-2012, 09:41 PM
FryLoch's Avatar
It's a Cobalt?
Old 01-22-2012, 09:44 PM
Originally Posted by FryLoch
It's a Cobalt?
:s pam::spa m:
Old 01-22-2012, 09:55 PM
05Slowline's Avatar
lol yea such a stupid system, the only time it's going to get that high unless there's a bigger issue is idling for a long ass time.
turn the fans on all the time if it makes you feel better, it's annoying as all hell though.
Old 01-22-2012, 10:01 PM
i have the left one wired to a switch so i turn it on when im on red lights but its annoying lol cant even let someone use my car cuz it will overheat lol
Old 01-22-2012, 10:12 PM
05Slowline's Avatar
IC pump being dead won't affect the engine coolant unless you're doing pulls.
Dunno any troubleshooting other than what you tried, maybe see if someone is nice in TX and has all 06's unlocked on their HPT and will help you out to just change the fan tables.
Old 01-22-2012, 10:18 PM
nhanson's Avatar
Have you looked at the fins on the radiator? maybe a bunch are smashed
or maybe its clogged/dirty?
Old 01-22-2012, 10:23 PM
05Slowline's Avatar
yea i was thinking maybe the dexcool is starting to clog but shouldn't the fans still come on regardless bc of the temp
Old 01-22-2012, 10:45 PM
i would cry of happiness if someone actually did this!
Old 01-22-2012, 10:47 PM
they look fine to me... would that affect fan function?
Old 01-22-2012, 10:53 PM
05Slowline's Avatar
or at the most if noone has them unlocked, pay 100 for the credits and the 5 minutes to turn the fans on. idk how people are where you're at i'd help a brother out for that though lol.
Quick Reply: cooling fans do NOT come on.
