cooling fans do NOT come on.
#52
[QUOTE=ECaulk;7612571][QUOTE=canadianviper;7612570]
[QUOTE=canadianviper;7612567]
It's all about airflow. You're still in a normal temp range, maybe a coolant flush and wash your rad off. I sprayed the rads out last week with a pressure washer at the local car wash
#54
I have this problem happen all the time. I eventually installed a switch to manually turn it on. I did a how to many years ago. The only thing is I have the switch wired to a constant power for when i was staging at the drag strip. Sucks if you forget to turn off the switch. I would recommend tying into some that is only on when the key is on
#55
The fan I don't have wired to a switch now comes on when around 187-190 on low ... Just like it used to. I still left the other one wired to a switch ... I tested the wiring by wiring my headlight halos to see when the halos would come on and they've been working... I'm going to rewire everything back to normal this weekend. Seems like I'm good to go after replacing Tstat, coolant temp sensor , and checked the wiring.
roth
09-26-2015 12:16 PM
