Engine light, traction control, power steering, gauges! - Cobalt SS Network
Thread Tools Search this Thread
Old 02-27-2008, 03:08 AM   #1
Question Engine light, traction control, power steering, gauges!
I have an 06 Cobalt LT I bought in August of 2007.
I brought it in for it's first scheduled maintenance on Feb 19th to get an oil change. The next day when I start it up, the traction control lights up and power steering shows up on the Info Console. I though, that's weird. I goes away when I'm driving home from work.
Next day, the Engine light, Traction control, power steering all show up and the transmission shifts at the wrong times, the engine stuttered when deaccelerating to the point where it sounds like it's going to shut down, the speedometer and tach needles are all over the place and the info console blinks on and off.
I brought it in to GM (still under warrenty) and had them look at it. They tell me the codes did come up, but after two days of diagnostics and road testing, they couldn't duplicate the same problems. I took my car back thinking everything was fine now. They kinda blamed the cold weather.
Now tonight Feb 27th, the traction control light comes up again. Sure enough, it's not working cause I made the tires spin and the engine didn't kick down at all.
Now what should I do here? Take it back again? Take it to another garage to look at it? Talk to the person who sold it to me?
Looking forward to hearing your input guys
Chippathingy is offline   Reply With Quote
Old 02-27-2008, 03:11 AM   #2
Original Hayden Fanatic
REIGN SS's Avatar
Images: 93
Check your fuses
REIGN SS is offline   Reply With Quote
Old 02-27-2008, 03:12 AM   #3
Images: 230
sounds like a loose ground or a nasty short somewhere.
3fo893013L is offline   Reply With Quote
Old 02-27-2008, 09:28 AM   #4
Images: 2
I will go with the loose connection or fuse .Final answer
Coblasts is offline   Reply With Quote
Old 02-27-2008, 09:44 AM   #5
mine was doing that what the dealer said the ABS was the problem, some how my abs was messing up my traction control and they replace the whole abs system well i hope you can get it taken care off. what ur gonna wanna do is take it in when the lights are on, when mine was doing that the only way i could get the dealer to see what it was, was by driving it there and leaveing the car on and have them bring out the **** to the car and then they found my problem but it wasnt untill 5 different visits with the lights off for them to find it "'06 cobalts have electical problems"
jj13326 is offline   Reply With Quote
Old 02-27-2008, 02:11 PM   #6
Okay, well I took it back to the dealer to see if they can find the problem. Of course they said to keep it running when I get there. I gave the service techs some of the possible reasons that you guys posted here and they appreiciated that. Hopefully that will lead them in the right direction.
Thanks again guys! I'll let you know how everything turns out. ...my poor Cobalt
Old 03-05-2008, 10:34 AM   #7
Exclamation **update**
Got a call from GM and they tell me they are scratching their heads over the problems with my balt. They've test driven it for 4 days and the computer they hooked up to it shows that codes are popping up, but then they turn themselves back off. They don't know why the codes are appearing then disappearing.
Now they tell me they are going to be replacing the communication module and see if that works. I sure hope so!
So what is the communication module and what does it do?
Old 03-05-2008, 11:52 AM   #8
They are probably goin to replace the EBTCM (electronic brake and traction control module)or EBCM (electronic brake control module). It depends on who your talking to as to what they call it . That one module controls both your antilock brakes and your traction control. I've read both trouble trees for the "ABS light on" and the "traction off" and both show to replace the module.
fr33k is offline   Reply With Quote
Old 03-07-2008, 11:52 AM   #9
*UPDATE*
Well, I got my car back and so far it seems to be running just fine.
They replaced the BCM (Body Control Module), but only after another Balt came in with similar problems. The other Balt directed them to the faulty BCM, but even though that code never appeared on my Balt, they said that the problems between the two Balts were too similar. The service guy told me that if it wasn't for this other Balt that came in, they would still be scratching their heads over the problem(s). No matter what they checked, re-checked and tested, the codes kept coming back and shutting off on their own. They said they've never seen that before and even consulted with engineers over at GM to see what they might be able to figure out. Maybe my car is possesed?? Hahahaha!
But replacing the BCM made the codes go away. He took it out for a quick test drive and everthing seems to be fine.
I'm just happy to get my Balt back!
Any problems he said, and bring it straight back! I hope that's the last I even see of them... to be honest . Thanks again guys for your input!
Old 07-28-2008, 07:58 PM   #10
Quote:
Originally Posted by Chippathingy View Post
*UPDATE*
My Cobalt sounds like it is having the exact same problem as yours. My speedometer goes haywire, the power steering light comes on (and sometimes the power steering turns off for a little bit) and the most unsettling problem is when the car randomly shifts gears... It feels like i'm in a car with someone who doesn't know how to drive stick! I've taken it to the dealership 4 times now, but they have been unable to fix it. I've been online for hours looking for a possible fix. Did replacing the BCM work for you? The dealership tech suggested possibly having to replace the PCM. Any insight into this issue would be greatly appreciated!
hrd53 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
For Sale 2011 Fully Modded HHR (non-SS) chefhhr Complete Cars 7 10-26-2015 11:36 PM
Electrical issues as far as the eye can see... satisfied Problems/Service/Maintenance 3 10-19-2015 01:35 AM
Whats my cobalt worth??? Empty Pockets The Lounge 19 10-12-2015 10:18 PM
Slight issue RyGuy Suspension 4 09-21-2015 11:03 PM
Need help! 2006 Cobalt SC jthwjde Problems/Service/Maintenance 1 09-07-2015 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
