Evap Vent Solenoid
Evap Vent Solenoid
My car had a check engine light and the dealership said it's an Evap Vent Solenoid. Does anyone know what this is. It is being taken care of under warranty, but I'm curious about it?
And yes I did try a search. I found alot of info about Evap purge solenoid, but not vent solenoid.
1 Post
Not meaning to flame or anything BUT.......
Sorry, but they are not the same thing. The purge solenoid(valve) is located on the engine. And the Vent Solenoid(valve) is located under the car on the canister.
Item 726 (which is highlighted) is the purge solenoid. Note the location.
Item 26 in this pic, is the vent soleniod.
1 Post
here's a copy/paste from SI off of GMDealerworld.com.
DTC P0449
Circuit Description
A battery voltage is supplied to the evaporative emission (EVAP) canister vent solenoid valve. The control module grounds the EVAP canister vent solenoid valve control circuit to close the valve by means of an internal switch called a driver. The scan tool displays the commanded state of the EVAP canister vent solenoid valve as ON or OFF. The control module monitors the status of the driver. If the control module detects an incorrect voltage for the commanded state of the driver, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister vent solenoid valve.
Control Module Command
EVAP Canister Vent Solenoid Valve Position
ON - CLOSED
OFF - OPEN
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
Conditions for Running the DTC
The ignition is ON.
The system voltage is between 6-18 volts.
DTC P0449 runs continuously once the above conditions are met.
Conditions for Setting the DTC
The control module detects that the commanded state of the driver and the actual state of the control circuit do not match.
The above conditions are present for a minimum of 12 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
DTC P0449
Circuit Description
ON - CLOSED
OFF - OPEN
DTC Descriptor
The ignition is ON.
Update:
I replaced the vent solenoid gm part number 25932573
and this did not resolve my P0449 issue. could be wiring still i suppose, i didn't have my multimeter out on it.
Bill
Bill
Another update:
i took my buddy's purge solenoid for testing, cleared the code and turned the car on, in 15 seconds after cold start the same code showed up.
i replaced the fuses as well.
other than a faulty wire, what else could it be?
i replaced the vent solenoid on mine and got a low purge flow code. gonna replace the purge valve and see what that does. hopefully this works cuz i have an emissions test coming up soon
The vent selinoid opens up the vent canister,if you still have the code there could be still something wrong with the canister ,
Thats what Im thinking.
Sorry should of read the code better.
Check and clean the connector in that circut,any corrosion of the pins or water getting in will change the resistance and the voltage with it.Add some extra di- electric silicone to the inside of the connectors to help keep water out..
Another thing do you hear the trunk monkeys knocking ?
If so the selinoid must be working.
no trunk monkeys but I think the canister may need to be replaced as well. The Onstar rep said that the "lines maybe clogged." I'll replace whatever is necessary to fix the problem for my emissions test. When the vent solenoid shows up I'm going to see if that fixes it.
Bring this back from the dead, I replaced the vent and still have the code after clearing it with my scan tool, lines are good and voltage is good.... Any help on what else to look at? On's on the canister and cost? Dealer only part?
You can buy it at rockauto for 63 dollars. I forget the part number.
