Flashing check engine light with no noticable misfires?
Old 01-17-2017, 02:28 PM
tamadrummer's Avatar
08 SS/TC 76k miles. I hadn't driven it for about two weeks, due to winter weather. The other day I was cruising on the interstate at a steady 80-85mph when my check engine light started flashing. Absolutely no noticable difference in how the engine was running and no loss of power. I Checked the code and it was misfires on all cylinders. My plugs are probably 10k miles old andI made sure they were gapped properly. I do an intake cleaning once a year. Could it be a bad knock sensor? I cleared the code and it hasn't come back yet.
Edit: sorry I forgot. It has a catless downpipe, CAI, muffler delete, zzp intercooler and upper and lower charge piping, zzp bigger radiator, and has a trifecta custom tune. The tune was off when this happened.
Old 01-17-2017, 03:02 PM
RonSS's Avatar
Is the car stock?
I'd just see if it comes back.
Old 01-17-2017, 04:55 PM
Sorry, I forgot. It has a catless downpipe, CAI, muffler delete, zzp intercooler and upper and lower charge piping, zzp bigger radiator, and has a trifecta custom tune. The tune was off when this happened
Old 01-17-2017, 11:04 PM
Was it the p0300 misfire code?
Old 01-30-2017, 03:15 PM
jdbaugh1's Avatar
I have a supercharged l61 Cobalt and I had this exact same thing happen to me today. Only time it has ever happened and it was repeatable every time I went WOT. I could not feel the car stumble at all, AFR was normal and holding steady. I wouldn't have even known it happened if I hadn't noticed the light flashing.
So right now it is parked and waiting on new spark plugs but I am concerned because I have never seen anything like this. Car idled fine and cruised fine. During a WOT pull if anything maybe feels like power is down a little bit with the flashing CEL.
Old 01-31-2017, 09:37 AM
jdbaugh1's Avatar
Did some pulls on the way to work today and it seemed healthy. It seems to be higher load pulls that do it. In the higher load pull I again got the misfire flashing light and maybe could feel a loss of power. Not like a jolt or anything just less get up than usual. I have a freeze frame from when I threw the code if there is any telling information in there.
New spark plugs are going in today and I have a spare ICM to swap out as well. I would think I could rule out mechanical because it isn't a specific RPM and really only seems load dependent, otherwise it runs like normal. It seems fueling is normal as the AFR is right were it usually is. I even have my tune with lower ignition timing flashed.
Old 01-31-2017, 01:49 PM
jdbaugh1's Avatar
So I went to Mode $06 screen on my OBDII scanner and it looks like the misfires are coming from cylinder 1. Cylinder 1 is the one closest to the timing chain correct? I swapped the spark plug between Cylinder 1 and Cylinder2 and it didn't affect this count. I also swapped out the whole ignition bar assembly with another unit and it didn't change anything either. Unfortunately this leaves me with fuel and compression. I don't think my year old injector is having problems so as my luck would have it it appears something is proper fubared. I have compression and leak down kits so I suppose those are the next thing to check. I just figured if it was compression loss it would also not want to fire right while idling or cruising as the problem area is only WOT. I can even do non full throttle pulls and it seems to run fine with minimal misfire counts. Power feels good and healthy. Fuel pump and filter are around 5 months old.
This is why everyone says to sell your base model and just get an SS lol.
Old 02-01-2017, 09:30 AM
jdbaugh1's Avatar
Below is a video I took on the way to work hoping to capture the misfire flashing CEL event. But of course because I had the camera on it wouldn't do it. I decided to upload the video anyway so you could see how it is running. When I had the misfire light before I never felt anything. I wonder what the hell is going on.
