gauge cluster/power steering
#51
safety recall?
I checked fuses and stuff. not sure which box is the G201 but everything looked fine. i havent turned my car in about 24 hours or drove it since issue. i just went out to start it to see what happens and it turned fine along with gauges working and power steering, idk. it happens on and off, im guessing its a short or somethin
thank you
#52
I have an 06 ss/sc. its been doing this on and off and recently just started again but its worse. My security light comes on and my gauge cluster goes out. the only one that works is boost gauge, rest just bounce around. dash says i have no fuel, no power steering and so forth. usually power steering didnt go out but its out now. when i try turning the car, it doesnt even click over, after several attemps it eventually turns over. i have a new battery and alternator.. anyone have an idea of what would be causing this?
Ive been having the exact same issues as you. I found this part of the wiring harness was riding on the supercharger pulley. Has not happened since i fixed it. Could be related but im not for sure in your case.
