Evap Problem
Old 10-01-2009, 01:54 AM
redline4's Avatar
Evap Problem
I've heard of multiple things about the evap problems and was reading and i was talking to a dealership and they said that fuel system isn't covered after 36k miles...is this true? I was sreading about the emission equipment warranty and it talks about 50k miles.
And if they are lying how should i approach them when they tell me that again?
Also im getting a too lean code too and only thing i have is the CAI. But Im not sure whats causing it. I've clean the MAF multple times and its clean. A guy across the street said it was running leaning as well.
Old 10-01-2009, 08:46 PM
Coblasts's Avatar
Hows your idle ,If rough could be a vac leak.
Old 10-03-2009, 12:10 AM
xxxxsh4d0wxxxx's Avatar
Reset the PCM.
Disconnect the battery for 10 minutes. Put it back on the terminal. Start the car and let it idle for 5 minutes, no throttle.
The car will relearn the perimeters and it should be fine.
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
yellow dragon
09-28-2015 09:49 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Evap Problem
