GM #PIP4718: Oil Leak At Front Crankshaft Seal Area 2008-09
Old 10-02-2009, 11:45 PM
rukkee's Avatar
Service Information
Home Publications Number Search New Bulletins Bulletin Search Feedback Help
Document ID: 2355311
#PIP4718: Oil Leak At Front Crankshaft Seal Area 2008-09 Ecotec (RPOs - LAP lAT LE5 LE8 LE9 LNF) - (Oct 1, 2009)
Subject: Oil Leak at Front Crankshaft Seal Area 2008-09 Ecotec (RPO- LAP LAT LE5 LE8 LE9 LNF)
Models: 2008-2009 Chevrolet Cobalt SS
2008-2009 Chevrolet HHR
2008-2009 Chevrolet HHR SS
2008-2009 Chevrolet Malibu
2008-2009 Pontiac G5
2008-2009 Pontiac G6
2006-2009 Pontiac Pursuit (Canada Only)
2008-2009 Saturn Aura
2008-2009 Saturn Vue
Equipped with the following engines:
2008-2009 2.0L (RPO LNF)
2009 2.2L (RPO LAP)
2009 2.2L (RPO LE8)
2008-2009 2.4L (RPO LE5/LE9/LAT)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A technician may comment of an oil leak at the front timing cover/crank/pulley seal.
Recommendation/Instructions:
When the technician has determined the front crank seal is leaking replace the seal, pulley, bolt and drive belt.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
05-28-2022 03:47 AM
brandon04
10-21-2015 07:04 AM
agentirons
10-16-2015 02:11 AM
n20saturn
09-30-2015 12:26 AM
Trav3480
09-28-2015 02:46 PM
Quick Reply: GM #PIP4718: Oil Leak At Front Crankshaft Seal Area 2008-09
