Car randomly shutting off....
Old 05-09-2011, 06:10 PM
Unforgiv3n's Avatar
Hey guys, I have an 06 SS/SC and recently the car has been randomly shutting off. When the car shuts off it kind of feels like it stalled, the dic will flash -40deg, the RPM gauge will fall and the speedo will stay consistent. If I recall, the power steering stays on, however I think one time it went out(yes i have had the recall fixed). One other note is the Wide band will show --- like it does during fuel cutoff.
I am not getting any sort of check engine light and when the car is running there doesn't seem to be any loss in performance. Most of the time I have to turn the key off and turn it back on for it to start back up. This has probably happened 5 times in the last few days. Two of which the car would not start back up. I had to wait about 5 min before the car would fire. It would try to turn over but wouldn't start. Sorta like if I ran out of gas.
So what's the deal guys? Any starting points that I can check. Is it my fuel pump? fuel filter? electrical? is the fuel pump on a relay?
Any help is appreciated! Thanks!
Old 05-10-2011, 06:30 PM
Unforgiv3n's Avatar
bump.... any ideas?
Old 05-10-2011, 06:38 PM
cranemaster's Avatar
Check fuses, my lnf did this. Fuse was loose on the battery in the trunk. Fixed the problem, even the dealership couldnt figure it out.
Old 05-11-2011, 05:26 PM
kento19's Avatar
check your MAF, mine was a little dirty from changing my airbox and it used to happen to me. cleaned it off and made sure it was tight and never had a problem since.
Old 05-11-2011, 05:30 PM
07BoostedG5's Avatar
MAP sensor can cause this. I know, I have had it happen!
Old 05-12-2011, 08:31 AM
Coblasts's Avatar
Sounds Electrical.
Would check all the connectors on the ecm and fuse box under the hood to make sure they are seated properly.
Old 05-12-2011, 10:58 AM
MAP! check that 1st!
Wind
09-11-2015 06:57 PM
Getaway_Driver
09-08-2015 09:41 AM
brickloaf
09-06-2015 05:55 PM
Quick Reply: Car randomly shutting off....
