How to install PCV Valve- LSJ
Old 01-06-2016, 01:27 PM
Brandon Clement's Avatar
Hey guys!
So I am in the process of replacing my PCV valve that is located in the intake manifold between ports 2 & 3. and I was just curious as to how to put the new one in, i took the old one out by twisting it with a flat head screw driver, but i didn't know if putting the new one in if you had to twist it, push it in until there's a click or something, or if i just set it in and when i put my intake manifold back on it will seal its self? I just want to make sure i do it right before i put it back on because I'd rather not have to take everything apart again. lol
Old 01-06-2016, 03:02 PM
Slobodan Milošević
07blackg5's Avatar
lubricate the oring with some dielectric grease or something before you put it back in. And it just press fits in. It should be obvious if it is seated properly or not
Old 01-06-2016, 07:15 PM
ItalianJoe1's Avatar
It will just pop in and be seated, the new ones are much tighter than the old ones due to the new o-rings, so like he mentioned put a little grease or clean engine oil on the o-rings, and they should pop right in.
Old 02-05-2016, 01:00 AM
Trav3480's Avatar
Quick question as I will be doing this myself Friday or Saturday . Can I just remove the supercharger or do I need to remove the intake manifold as well ? If u have any pics would be a great asset. Thanks
Old 02-05-2016, 06:37 AM
Trav3480's Avatar
Nevermind , I found a pic showing it needs to be removed. Ugh well least I have 2 days off to learn how to do it.
Old 02-08-2016, 07:20 PM
izcain's Avatar
Pretty straight forward. Don't forget about the hidden bolt behind the manifold.
06blackbalt
01-30-2016 06:36 PM
patchedG5
01-01-2016 11:33 AM
brandon04
12-11-2015 08:06 PM
Quick Reply: How to install PCV Valve- LSJ
