Intermitten No start, No Crank, No click
I have been having this issue for about 2 weeks now. I recently had the clutch replaced, new lower control arms. Car ran fine for about a day then I had the no, start, No crank issue. Went outside one morning and the issue was there. came back after work same issue. Dash works, lights work, flashes power steering across the screen and low fuel because the fuel gauge will not go to the half tank mark. I've unplugged the power steering unit still no start. unplugged the battery to reset everything still no start. I haven't got the ignition recall yet. then one day it starts and drives fine. next day no start. next day start, next day start, then no start. I've tried the key relearn and still nothing. I'm at a loss any help would be appreciated.
I have the same problem on my 08 SS right now did you ever figure it out i am lost its at the shop and they cant even find anything it only happens sometimes but it leaves me stranded in parking lots any ideas? Theyve checked all grounds and battery and the starter and everything was good
Check the wires going to your starter. I had this issue after swapping my engine last month. no crank, no nothing. swapped a known good battery, still nothing. jiggled the starter wires and heard a click. took the wires off, wire brushed the eyelets and bolted them back to the starter and been fine since.
A bad ground, low battery, bad starter, bad ignition switch, bad clutch pedal switch in manuals or bad brake light switch in automatics can all cause a no crank situation.
