Issue with Intermediate shaft install...I done screwed it up
Today I decided to replace my clunking intermediate shaft. I installed it with the steering wheel in the wrong position took top shaft end off of electric steering motor shaft, fixed the steering wheel and tried to reattach the top shaft end. I must have installed it wrong the first time and drove the bolt through the splines of the output shaft and now I can't tighten it the right way so the car is out of service. Can someone in the know tell me if the output shaft on the electric steering motor is replaceable? It looks like it can be unscrewed but I'm not sure. Car is laid up, help!
Not sure that it is
Either way your gonna have to pull ps motor either way. Find one used on ebay or something seen them cheap.
Ive replaced mine 4 tomes and still not sure what you said you did. It has a clearance for the bolt on the splines did you not push it on far enough and ate up the splines???
Not sure that it is Either way your gonna have to pull ps motor either way. Find one used on ebay or something seen them cheap. Ive replaced mine 4 tomes and still not sure what you said you did. It has a clearance for the bolt on the splines did you not push it on far enough and ate up the splines???
The shaft in question is the shorter one pictured in this ebay listing. If I were to buy this item, could it be replaced without tearing the steering column apart? I've already replaced the electric steering motor on this car so I am familiar with the process
http://www.ebay.com/itm/CHEVROLET-COBALT-Steering-Pump-electric-motor-05-06-07-08-09-10-/400701762185?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d4bafaa89&vxp=mtr
If you have a link to the steering wheel removal that'd be great, if not I can search for it. I'm pretty sure I saw a "How-to" for the turn signal column that should tell me what I need to know. I'd hate to have to tear into the steering column but it looks like thats what I'm gonna have to do
UPDATE: I attempted to re-groove the splines on the shaft that connects to the top of the intermediate shaft and found that to be pretty tedious. After about half an hour of trial and error I said "screw it" and filed away the bad splines and that worked.
Only question I have now is, since my steering wheel is 90 degrees off center what is the procedure to correctly "align" it? I did spin the wheel with the intermediate shaft off and I am aware that's a big no-no. Hopefully you sages on here have some wisdom for me!
Thanks
Thanks
Right, I figured that much. I guess the more pointed question is, how do I know I have the steering wheel in its center, ignoring the intermediate shaft. Is it more or less a guess? I wouldnt want the wires in the steering wheel to bind/ chafe and cause hell that way
Just get out and turn the tires visibly straight then unbolt it and straighten up the wheel and go for a drive. Assuming your alignment is good you will know where you stand and can adjust accordingly.
Be careful, while doing my clutch I had my buddy help and he installed my steering shaft 180° off, so my steering wheel was upside down; when I corrected it and started driving again, my clockspring went out a few days later.
UPDATE: Well guess what happened once I aligned the steering wheel the "correct" way... I went to make a tight right turn in a parking lot, the wheel got very tight and the "Service Air Bag" light came on. Did a little research and it turns out I broke the clock spring. There has to be a more scientific way to get the steering wheel in the right position so it doesnt mess up the clock spring. Has anyone had to reset their wheel before?
I hate to admit this but maybe it will save some other poor soul from making the same mistake... The (EXTREMELY UNSCIENTIFIC) way I found my "center" was turning the wheel (disconnected from Inter. Shaft) all the way to the left till it got tight, thus giving me my LEFT limit, counting the number of full rotations I spun it to the right till it got tight, giving me my RIGHT limit. I split the difference and figured that would be a good enough way to get my CENTER. Someone please enlighten me on the proper way to find my center and if possibly any tips for replacing my clock spring.... THANK YOU
Edit: Cruise no longer works and horn no longer works as well
Boom
https://www.cobaltss.net/forums/how-...cement-309567/
I hate to see people making easily preventable mistakesmThere are directon here that very clearly tell you not to let your steering wheel rotate while changing the shaft. Next time use google and search for directions first almost everything you will need to do to your car has a how to on here.
importkiller
09-30-2015 07:18 PM
