A little help needed. Evap codes
So the last week I've been getting P0446. I have been able to clear it only for it to come back 2 days later, every time. Today I removed the canister and blew into it, only to meet 100% resistance, and was unable to blow through it, meaning the canister is still good, right? Unless it is stuck closed? Anyway, I reinstalled it and ordered the part anyhow. I tried to clear the code again only to see two codes this time! And I was unable to clear P0446 this time! Car is idling a little high, around 900-1000 mark but slowly comes down. I have pictures of my log I will attach, but any help is appreciated.
Ok that is a tank pressure code. Not enough pressure so u have a leak somewhere. Fist check ur gas cap to make sure it's on properly. If that don't work, try replacing the tank pressure sensor on the canister , black thing under ur car back behind ur gas tank. If u changed the solenoid on the intake, thAt probably isn't ur issue.
Goto rockauto.com and look for this stuff
AIRTEX / WELLS Part # 2M1084 More Info {#15788844, 15795021, 17114055, 21993142, 22865590, 25321964, 25932573} - evap vent solinoid
May Require 1P1793 Jumper Harness Connector for Installation because of OEM Redesigned Vent Solenoid
I will need the connector to cause the solinoid has different plug than original, they all come like that now .
ACDELCO Part # 13502903 - fuel tank pressure sensor
