New Oversized Tensioner rubbing
I'm on a 2.6 pulley.. My old oversized tensioner pulley started to make noise so I was replacing it and the new pulley rubbed on the top of shock below it.. Does anybody know what would cause this? The new pulley is exactly the same as old one and the old one never rubbed
Why would the oversize pulley have an offset? The stock pulley doesn't have an offset. One would think putting an offset pulley of a bigger diameter in it's place would cause a belt misalignment. In OP's situation it sounds like he is rubbing on the top of the actual vertical tensioner. If this is the case I would think the pulley has to be bigger because the only dimension that should cause that is pulley diameter.
Are you sure the pulley's are the exact same diameter? Is it a light rub or does it prevent the whole pulley from spinning?
