odd electrical problems
few little weird problems:
1. headlights will flicker sometimes while driving and sometimes radio will turn off and right back on. Headlights will also flicker sometimes when hitting the brakes.
2. When alarming the car, sometimes one button push will lock the doors and sound the alarm horn rather than the normal two. Also, sometimes the headlights will remain on even when the lock button is pushed.
3. Has happened three times...when starting the car, the car won't crank. Turn key back to off, then back to crank and it starts. When it starts, the needles go back...like towards the bottom of the gauge instead of up. After a few seconds they will correct.
4. When turning the car off, with the clutch to the floor, the engine will stumble and almost feel like a half stall, if that makes sense at all. Kind of hard to explain. After it is off, the needles will twitch for a few seconds and then die
5. Sometimes, the car won't respond to the keyless entry but after a few tries it works
Mods are in my sig. Bear in mind, these issues have started since it got cold. I'm thinking the battery is dying. Any other thoughts?
Thanks
Thanks
My gauge needles twitch too. When I shut the car off, they reset to 0, but then 30 seconds (or so later) they drop below 0 and twitch a little, and then settle below 0 about 1 cm. Nothing concerning there - the gauge looses power and the gauges need power to stay at 0.
yeah but they keep moving, like it's getting power
my 08 twitch and read 10 everynow and then havent had the time to bring it to the dealer im sure its nothing seroius though; but every now and then my car after starting the idle will dip down like a vaccum problem havent brought it in yet
I'm old school
Flickering anything (lights or needles) is not a condition of a weak battery. Its a bad connection, causing voltages to switch quickly between 12 and zero. You have a bad cable somewhere.
right now I'm guessing alternator. Car wouldn't crank when I was leaving work tonight. Held it for about 15 seconds and eventually it started. Now I have a CEL
Thoughts?
Thoughts?
I dunno man, maybe a bad ground on the PCM or BCM. The gauge needles flickering are just them loosing power, its normal. Get the code scanned and see what it is.
happend to me w few weeks after i got my car... i had installed a sub and amp inthe trunk and the power cable to the battery was just the TINY bit loose and that was the problem. Just loook at the battery make sure all connections are perfect.
Right now I'm sitting at the mechanics. After scanning everything, I threw two codes, a 335 and 340, both of which are crankshaft position codes. After digging some more, we came up with a readout indicating that the ignition is (most likely) the cause. We're waiting on the new one now so we'll see what happens
I'm old school
P0340 is the intake cam position sensor circuit. If both your crank and cam position sensors are throwing codes together, it's just another indication like your headlights flickering on and off. They are intermittently having their power interrupted.
If you mech thinks its the ignition tumbler, go with that for now. It's certainly a possibility. But again, it's more then likely just a bad wire or connection somewhere (always go with the simplest explanation first).
the ignition switch was a fail. We tested the starter and it had ZERO power. We also noticed that the security light was blinking on the dash. We manually bypassed the starter and the car cranked, so now we're thinking the car de-learned the key or something. We're trying a case relearn and we'll see where we go from there
