stock headlight lighting problem - Cobalt SS Network
LinkBack Thread Tools Search this Thread
Old 06-05-2008, 04:43 AM   #1
eurochevy's Avatar
Images: 76
so i noticed when i was leaving my buddies house like 20 min ago that my left headlight doesn't work ...well to an extent..because when i go on high beams it turns on..only when its just regular beam that it doesn't come on..so obviously a electrical issue and not the bulb ..any one have any ideas?
eurochevy is offline   Reply With Quote
Old 06-05-2008, 04:46 AM   #2
Check the low beam fuse. There's two separate fuses for both high beam and low beam.
ssweeet is offline   Reply With Quote
Old 06-05-2008, 04:47 AM   #3
eurochevy's Avatar
Images: 76
Quote:
what number fuse i'll actually go check it right now..the fuses if they go out haev a line taht goes through the middle on the top saying its out or w/e right
Old 06-05-2008, 04:48 AM   #4
I'm not sure, just pull out your manual and look it up in the engine bay fuse box.
Old 06-05-2008, 04:57 AM   #5
eurochevy's Avatar
Images: 76
k i went out and checked..didn't see any thing wrong with it..but weird thing is that i just learned! = when you push the button on the key to unlock the doors...it will come on but once you open the door or manually put on the lights it will not come on..push the button it will come on so like seriously WTF lol
Old 06-05-2008, 05:30 AM   #6
Images: 9
unlock light uses highbeams, not low
at least mine does. never know these days.
esfkotaro is offline   Reply With Quote
Old 06-05-2008, 06:02 AM   #7
Images: 21
Quote:
pretty sure its the bulb. 9007 bulbs are dual filament. the low beam filament is probably fried.
Jesse_Chouinard is offline   Reply With Quote
Old 06-05-2008, 06:07 AM   #8
Original Hayden Fanatic
REIGN SS's Avatar
Images: 93
Yes, this seems to be very common in the Cobalts, the headlights are dual filament and the low beam one went out. Just go buy a new bulb and you should be golden
REIGN SS is offline   Reply With Quote
Old 06-05-2008, 02:16 PM   #9
eurochevy's Avatar
Images: 76
well they're after market bulbs but i got a spare one sitting ni my room because i had to buy a new set of 2 because some guy hit my headlight and it smashed over night i'll try that out..when it stops raining!!!!!!!!! although that could be for like a week lol
Old 06-05-2008, 06:15 PM   #10
Images: 6
i have gone through 3 pairs of lights 30$ 50$ and 90$ what is the deal.. If i get hids would it still burn out
mattmatt is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Electrical issues as far as the eye can see... satisfied Problems/Service/Maintenance 3 10-19-2015 01:35 AM
Appearance: LED Side Marker Lights Jesse How to Guide 57 10-15-2015 12:56 PM
For Sale Stock SS/TC springs and Stock SS trunk with high rise camaromanss1992 Parts 3 10-01-2015 11:51 PM
Floaty light rear? ATOMbomb Suspension 9 09-11-2015 11:48 AM
Need help! 2006 Cobalt SC jthwjde Problems/Service/Maintenance 1 09-07-2015 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
