Sunroof
Old 07-20-2009, 09:42 PM
BallinBlackbaltSS's Avatar
Sunroof
Ok i was getting home i started to close my sunroof and i heard a crackin noise, when i got out and looked right side of it was still open a little bit.. any one have the same problem? or know what it could be?.. and how much it could cost to get it fixed.. that would be great thanks...
Old 07-20-2009, 10:05 PM
E-Town SS's Avatar
Is your sunroof tracking straight? That's be the first thing I would look at. If it's not, the compression against the body may have cracked the glass.
Or maybe it's something as simple as some dirt/dust/sand in the track and it's grinding.
That sucks though. I feel your pain.
Old 07-20-2009, 11:34 PM
looked at glass doesnt see any cracks or brakes... but i don know... maybe i just take it off my self or something.... crap!
Old 07-21-2009, 07:29 PM
SS Gordon's Avatar
Mine just did the same thing Saturday & I took off the glass to see the track & lock tab was broke & it stays open unless you align the lock latch on the drivers side
I have an appointment at the dealers tomorrow night & I'll try to remember to let you know what they say!
Old 07-21-2009, 07:42 PM
bshoe421's Avatar
that happened to mine, the frame broke. it was too much to fix so they shut it and i pulled the fuse. if your under warranty take it in a get it fixed if not its quite a bit of money to get fixed.
Old 07-22-2009, 01:48 PM
akbar87's Avatar
Mine broke this last Saturday to me. The driver side went down fine, but the passenger side was stuck up a little. It was about to rain so i had to fix it. I ended up loosening up the 2 back bolts on the passenger side (T 25 bit) and there is a plastic black piece that guides the window down into place. I moved that forward a little with a flat head screwdriver and tightened everything back up and tried it a few times to make sure it wasn't going to mess up again. Everything seems to be working fine now. It has been raining the last few days and i have been watching for any leaks. Nice to say that i have not found any.
Old 07-22-2009, 06:53 PM
SS Gordon's Avatar
Well I was lucky I bought the extended wqarranty as it is the whole frame to fix it & it was listed at $550 for just the parts & I can only imagin the labor at about $200!
Hey akbar87 I was able to also get it to shut by aligning that same piece but that piece is supose to move forward after the sunroof shuts & that lifts the rear & locks it so it sounds like the same piece is breaking on all the sunroofs & that suck it's a $700 fix like I said I'm lucky I have the extended warranty cuz it's just $100 deductable!
Old 07-23-2009, 11:21 AM
akbar87's Avatar
I was looking on gmpartsdirect.com and the frame on their web site is only 132.08. Probably not the easiest to replace tho.
Old 07-23-2009, 01:13 PM
SS Gordon's Avatar
Wow what a markup ??
Old 07-24-2009, 05:55 AM
papasmurf's Avatar
I just did the same thing from an earlier post. All I did was take the glass off and look at what was wrong. Was a lil off track so I just re-aligned it, and its good to go. Its pretty easy, only 6 screws if you wanna peek and look.
Old 07-28-2009, 02:47 AM
Well i pushed that tab forward it closed, its good im not gonna open it i have extended warrenty but i doubt it covers that plus 100 deductible...so im guessing the bracket is broken... so no money no fix right now but its sealed so i guess im ok with that still pissed off tho..... >
Old 07-28-2009, 02:48 AM
Old 07-28-2009, 02:50 AM
Old 07-28-2009, 02:54 AM
01-12-2016 12:01 AM
chefhhr
10-26-2015 10:36 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
jthwjde
09-07-2015 09:24 AM
Quick Reply: Sunroof
