TOB Talk. More failure
Have done half a dozen clutch jobs and never had an issue until this 2009 IMB LNF I bought.
Pulled my KY last night and it had completely adjusted itself and ruined the disc. < 3k on it. Previous KY did the same thing with less than 5k on it. Anyways the TOB was also making that clicking noise at idle. Pulled everything, installed new clutch and OEM LNF TOB. Got it together and the TOB seal blew bleeding it. So now I have has two bad LNF TOB that came from totally different dealers fail.
Install was correct. I've done this several times and nothing was wrong. Didn't try and bench bleed it. Let it gravity bleed while doing some other work on the car. Did a traditional bleed. Had pedal pressure on the third go. Did two more to get air out and "pop".
I've done everything Omniotek and Powell and Belvedere all say to do when installing, but still failures.
Now what? I am sick of these things failing. Should I use a LSJ one? Dorman or Centric one?
I have that clicking 2. I did my own clutch 15000 miles ago replaced with Gm upgraded clutch. I hear that clicking noise at idle. It would be hell all over again to tear it down on the ground. It's going to stay clicking till it fails lol
The seal blew ? Then could it have overextended? As in either a resurfaced flywheel or clutch disengagement teeth to far in? . Only 2 things I know that can blow the seal on a tob. Out of all the lnf tob I have installed. Not 1 failure. At the same time I've done mostly gmpp installs and my own southbend stage 4 clutch. Pulled about 4 times and reinstalled. No issues.
This sounds really dumb but did u make sure all the bolts were in on the tranny n properly torqued down? Because I had 3 tob failed on me because I tried to half ass it and only installed half the bolts on so that when I bled it, if it failed then it would be easy to take back apart again. Lol it was late n I wasn't thinking right after working on the car for over 12 hrs. Just make certain everything is aligned properly, torqued down to proper spec, and hopefully u don't get a faulty tob. Hope this helps... good luck man.
im not trying to sound like a dousche bag here man but theres one of 2 things going on....... either its something with your clutch flywheel setup or your installation. the fact you had a seal blow during ibleeding makes me thing theres something wrong with your installation process somewhere. i have done probably 30 clutches in cobalts alone and i have NEVER had one blow to this day.
powell and i both agree on 98% of these installs and failed throw out bearings being installer error. not saying you did anything wrong without proof but i have found a ton of issues that happen when doing the install. last guy that had a "failed tob" ended up causing him a case.
my opinion is this trans should not be done on your back as i have found theres too many potential issues. what clutch setup did you end up throwing back in it after we talked and i told you to go with a spec clutch
Omiotek what is the torque spec for the TOB? Makes me wonder if a torque wrench out of spec could cause over or under tightening allowing this issue to happen, just talking out loud not sure if that would even effect the TOB install.
Torque spec doesn't matter but the mounting surface needs to be CLEAN, FLAT and the TOB needs to be tightened down evenly and securely.
They blow the seals out if there's a bolt missing, they aren't sitting on the case properly, etc. It's not a great design and there isn't a lot of room for error but if you do it right you won't have an issue.
I'm with Omni, I have done at least 10 cobalt/ion clutch jobs myself, only had one TOB fail during bleeding and that was on my first one where I broke one of the bolts and figured with the other two it would still be ok. Did exactly what you describe, failed after it built up pressure. Replaced that TOB and took out the broken bolt and replaced it, was perfect. Never had another one fail on me.
