turns but wont start
2006 cobalt ss was running fine, stopped at a stop sign stalled and wont restart! Motor turns, fuel pump works. Seems their is no fire, I dont know were to start. It was really rainy and I have an injen cold air, could this be part of the broblem?
take off the piece that covers your fuel rail. on that rail there is a spout that resembles a stem valve on your tire( the one you put air into).This is what you need to try, turn your key on and wait about 5-10 secs. Then turn your key off and go to that spout. with a flat head screwdriver stand with your face out of the line of fire and push in the stem inside the spout. This will tell you if there is pressure on your fuel line. No pressure means no gas being sent. AKA your fuel pump is either bad or has come unplugged. Mine came unplugged on my 06.
If your not throwin any codes its hard to pin point your issue. I had the same issue you had and it turned out to be my fuel pump. So I' suggest starting there first. Do what I said and mark that one off if it isn't the fuel pump move on to the fuse relay under the hood fuel pump fuse relay might have gone out also
Also, if the fuel canister broke like has happened on some of the early cars, you will hear the pump but have no pressure. Test it from the port on the rail as mentioned above, if you want to get an actual gauge it needs to read 58psi after the pump has run, but there should be a very solid spray of fuel if you just push in the schrader valve in the port.
Is there gas leaking under the car by chance?
Doesnt seem to be gas leaking, as for the pressure theres some build up but no a strong spray, but I dont have a fuel pressure tester to test it.
But havent got a spark from starting with the spark plug out...
If you dont have spark you will be cranking for a long time and nothing will change. is there spark on any of the plugs or is it just one? hold the tips of the spark plug onto the engine case (or any metal surface) and have a buddy turn the car over. (make sure you are not touching the plugs themselves! you will know if you do)
Someone mentioned this earlier but did you check fuses? I looked at a wiring diagram at work today and it showed the injector fuse feeds batt+ to all the coils, not a bad idea to check them all though
roth
09-26-2015 12:16 PM
