Recalls Chevy Cobalt recall information center
power steering fail after recall.
Old 01-21-2015, 03:24 PM
06cobalt racer's Avatar
i had my 06 power steering motor replaced 3 months ago. before the recall the steering never failed. the other day i was turning into a parking lot and the steering failed. pushed in the clutch and restarted the car and all was good. called the dealership and they looked at it today. first question they asked me after looking at it was if i have ever needed to jump the car. i told them no, i have never had it jumped. he asked that because the tech said that i had 3 codes for low battery voltage. the battery is about 3 years old or so.
when i got i switched my interceptor gauge to battery voltage. here is what it showed...
driving - 14.5 volts
idle - 14.3 volts
sitting off with key on 1 minute - 12.4 volts
sitting for 5 minutes - 12.2 volts
does this sound like a bad battery? i know i can have autozone or anyone test it but i dont have time for it right now. i can do that this weekend.
thoughts??
Old 01-21-2015, 03:28 PM
Sl0wbaltSS's Avatar
inb4recall number 2
Old 01-21-2015, 05:38 PM
inb4recall number 2
Lol hope not
Old 01-21-2015, 05:51 PM
At sitting your battery should be no less than 12.6v
Old 01-21-2015, 08:15 PM
Granted my test was with the key on. It probably would have dropped slower if the key was off and I just used a multimeter at the battery
Old 01-28-2015, 12:16 AM
ok well i took my car to autozone to have the battery tested. it failed. got a new battery, installed it and the steering went out 9 times today! everytime it went out the voltage was at 14.4-14.6. this is really pissing me off.....
Old 01-28-2015, 12:30 AM
Spawne32's Avatar
I have long speculated that there is an issue with the control module under the steering column and not the actual steering motor itself. Is your power steering failing while the car is moving, or is it when you go to turn in a stopped position? I had to raise the idle on my car to 750 to give the electric steering motor sufficient charging current to actually allow the motor to work properly. A weak alternator can aggravate the problem at idle i know that much. I also posted a link in another thread about a canbus problem with an oxidized connector causing an intermittent connection at the power steering module which caused a power steering warning to display on the DIC. He fixed the problem by cleaning the inside of the terminals on both sides with deoxit 100 terminal cleaner.
Old 01-28-2015, 12:47 AM
it is failing while i am driving. come to think about it, it has never failed at higher speeds. meaning 35 and up. it has only failed while driving on base. speed limit on base ranges from 15-25mph.
Old 01-28-2015, 02:38 AM
what were the codes? and how u got interceptor and not know you got codes?
thats sketchy about the steering going out continuous like that
Old 01-28-2015, 12:25 PM
I don't know the codes. Dealership didn't remember them when I asked. All they said was that it was 3 codes relating to a low battery. I always check my interceptor and never have any codes on there. As far as I know the interceptor only reads engine codes not body or steering codes. I could be wrong.
Yeah it is starting to pass me off.
Old 01-28-2015, 03:35 PM
oooh right that would make sense
Old 02-04-2015, 01:41 AM
just to keep this updated.
so the steering has been going out A LOT!! usually 4-6 times per day. today it went out 10 times!
i am taking it back to the dealer again in the morning. this is all after i got a new battery.
Old 02-04-2015, 11:15 AM
let us know what they discovery, thats prettty crazy
Old 02-04-2015, 01:43 PM
Yeah I will. Dropped it off at 10. They said that hopefully they will know something by 2 or 3....
Old 02-05-2015, 01:10 AM
it took the dealership 7 hours to look at it. after all that time they never found anything specific that was wrong with it. they ordered a new power steering motor to see if that will fix it. they think they might have gotten a bad one for the recall. they said that if it isnt the motor that it might be the column itself. the part will be here in 2-3 days.
Old 02-05-2015, 11:13 AM
are they taking care of you at least?
the power steering going out that many times smells like a lawsuit waiting to happen
Old 02-05-2015, 11:14 AM
Yeah motor is free. If it is the column then it is not free
Old 02-05-2015, 02:17 PM
footballplaya3k's Avatar
The column is expensive.
Old 02-05-2015, 02:22 PM
Spawne32's Avatar
Oh boy, someone is about to get robbed. lol I'd put a stop to that before they do the column.
Old 02-05-2015, 02:57 PM
oh yeah. replacing the motor is fine. i wont have them replace the column.
Old 02-05-2015, 03:54 PM
ForsakenOutlaw57's Avatar
Yeah I'm going to pay attention to this. I am having failures too and I just had the power steering motor replaced last month. I have a video of what it does and I'll post it later but the gauges are flat, the power steering doesn't come on, and it takes a while. Today I almost got all the way to the train station before the power steering motor kicked on - it was dead from when I turned the car on and yes I went on the highway too. It's a total pain in the ass! I'm going to call the dealer back too!
Old 02-05-2015, 08:44 PM
Mine works when you first start driving. But then goes out every couple minutes
Old 02-05-2015, 09:10 PM
Shanedude's Avatar
Drive safe in the meantime.
Old 02-06-2015, 12:05 AM
yeah i only drive on base with it. speed limit of 15-25 mph. if i go off base i take our van
Old 02-06-2015, 12:18 AM
SLRdohc's Avatar
mine has been out for awhile. has soon has I turn the wheel it goes out. So been pretty used to the non power steering crap. Getting ready to replace the motor unit soon. Hopefully it is that. Found the PS motor on ebay for 90. My vin doesnt check out has a PS recall which is BS> oh well
Quick Reply: power steering fail after recall.
