clay bar replacement
If you use a polisher, I found these things:
https://detailersdomain.com/NanoSkin...ide_p_706.html
This thing works better than clay, and I was able to do the entire car in about 15 minutes or so. Ran that, a 1500 grit & 4000 grit Menzema and used a heavy sealant (instead of a shiny one). Took about 2 hours total:
The disk is as flexible as your backing plate, so if you use a 5 or 5.5" plate, you'll have about 1/2" of flex on the edge for getting into tight spots
Nothin Stock
I've read great reviews on this item. Another alternative, if you don't have a machine, is this item. So much easier than using clay and doesn't mar the paint.
There are some clothes and sponges on autogeek that one of my supervisors swears by. removes foundry fallout better than clay he says and that stuff sucks to get off your car.
DANRICKARD
10-01-2015 12:08 AM
