Invisible Online Status?
i have the edit options under user cp but dont see anything about invisible mode. i have an option for a vcard at the very top and thats about it. ill keep browsing around. Its gotta be here somewhere. At least i'd think so
I just went up to the user cp on the right with the down arrow. when the menu drops down pick edit options and the very first thing on mine says "use invisible mode" the second thing says "allow v card" . Maybe you have to use that user cp on the right with the drop down menu. Its there on mine though.
oh damn thats weird it just showed up above the vcard. it literally was not there five minutes ago. thanks guys.
Edit: now its gone again. Now I cant get rid of it if I wanted to. Weird stuff.
click on your private message on the top of the right screen where you user name is, then the next page has a scroll of options on the left under setting and options, click edit options and then it right on top, click the box that shows Use Invisible Mode, that how i did mine.
umm weird a way you know its working look at any post in any thread on your screen any other member on with show green and clear for off, but yours will show red for hidden like mine does, for you mine should appear clear, just a tip so you know if its working
I've seen people with red indicators. I've never seen the option for invisible mode though. The only option in that one section on mine is for the vcard. Nothing in there for invisible mode (even though even the forum help says it should be there too).
Go to the quick links deal, click on that then go to edit your options.. then "invisible mode" should be the first thing you can change. I just did it, usually it has that green dot that shows your online but mine is red now and says im invisible
Montero32
Sep 11, 2015 09:24 PM
