No more stock on 2008 cobalt ss/tc
#78
Dude its right in the numbers, it makes full TQ @ 2000 RPM, its not the same turbo used in the MS3, its smaller.
The TC makes all of its TQ before the SC Does, the SC has that lag till 3-4K+ RPM to get the last few pounds in, the TC is full power by 2000 RPM, just goes to show that it even has more low end then the SC Model and reaches full potential much faster, i really dont see any benefit to the SC model whatsoever, you say the SCs main strength is it makes low end power, yet the TC Model makes more low end and more instant power then the SC Model, and considerably faster
#79
And 100% power in the low end doesn't make it reach its 'full potential' faster. It makes you spin the tires more and have no top end.
Isn't it a k04 or k03 the turbo used in the MS3?
Like I said, I've given a bit of gas to a Sky Redline..lighter..rwd SAME ENGINE and it doesn't give that 'full push' until the 3K area, it doesn't give all that power in the low end.
And again, I know GM never lies with its numbers.
#80
the low wing is gonna be standard on the ss/tc, it was the standard one on the old 2.4 SS's. the high rise wing is optional on the ss/tc. they are not the same shape/design. high rise on the ss/tc is claiming like 23lbs of downforce at 70 mph.
also my ss/tc was ordered over a week ago and i was told 4-6 weeks but expect it closer to 4 weeks in either the last week of april or the first week of may. if infact there are delays and i don't receive my car within that 4-6 week period i will be bitching at the salesman for some free stuff. nothing like some free oil changes and a key chain.
#81
^^^I'd expect about 6 weeks. Dealers everywhere are trying to get their hands on this car.
As for the LNF turbo conversation, I'd like to add that even though the turbo allows the tq peak to be at such a low rpm it is a very long way to the peak hp at 6300 rpms. The ting I find funny about all of this is that everybody knows that the tq and hp curves cross at 5252 rpms. That means you have to rev through 3252 of decreasing tq before the increasing hp makes any real diff even though it still has to increase by 1048 rpms to make peak hp. 4300 rpms is a long valley between peak numbers. Good thing the hp curve would be a steeper incline versus the angle of decline of the tq.
#82
Were it not for all the other upgrades that are coming with this car (New seats, Brembos, strengthened drive components, No-Lift-Shift, Launch control, Stablitrack) I would try to find an '07 with the G85 package (must have Recaros)
#83
2008 Cobalt SS
http://media.gm.com/us/powertrain/en...obalt%20SS.pdf
2008 Sky Red Line
http://media.gm.com/us/powertrain/en...0L_LNF_Sky.pdf
2008 Ecotec 2.0L I4 VVT DI Turbo ( LNF )
ECOTEC 2.0L TURBO I4 (LNF) CAR and TRUCK ENGINE
2008 Model Year Summary
Carryover content and benefits from 2007 model year.
New Engine for 2008 Chevrolet HHR SS and Cobalt SS
Direct Injection
Twin-Scroll Turbocharger
Air-to-Air Intercooler
Unique Cylinder Head with Sodium Filled Exhaust Valves
Continuously Variable Valve Timing
Gen II Engine Block
Aluminum Pistons With Jet-Spray Cooling
Forged Steel Crankshaft
Cam-Driven High-Pressure Fuel Pump
Full Description of New and Updated Features
The Ecotec 2.0L I4 VVT DI Turbo (RPO LNF) powers the Chevrolet HHR SS for 2008 model year. This Ecotec engine is installed transversely, and equipped with either a Hydra-Matic 4T45 four-speed automatic or GM F35 five-speed manual transmission. Additionally, with the introduction of the LNF for 2008 model year, we now carry this Ecotec 2.0L I4 VVT DI Turbo engine offering into the popular Chevrolet Cobalt as it sports the SS moniker. The Cobalt SS is equipped with a GM F35 five-speed manual transmission.
Carryover applications from 2007 model year include the Solstice GXP and Sky Redline roadsters. This Ecotec engine is installed longitudinally, and equipped with either a Hydra-Matic 5L40 five-speed automatic or Aisin AR5 five-speed manual transmission in these applications.
The 2.0L Turbo is GM Powertrains first North American engine with direct injection. With advanced turbocharging technology, this is a true high-performance inline four, generating 260 horsepower and 260 lb.-ft. of torque. The 2.0L Turbo is not only the most powerful Ecotec engine: At 130 horsepower per liter, or 2.1 horsepower per cubic inch, it has the highest specific output of any GM production engine, ever.
Direct Injection
Given more than a century of development behind the internal-combustion engine, direct fuel injection is new technology. Direct injection is the culmination of the engineers quest to move the point where fuel feeds into an engine closer to the point where it ignites. The advantage is greater combustion efficiency. Direct injection allows the Ecotec 2.0L Turbo to generate outstanding power, while consuming fuel at the more frugal rate of a conventional small-displacement port-injected engine.
In a port-injected engine, the combustion process begins when air and fuel are mixed in the intake manifold or intake port before they are introduced into the combustion chamber. Direct injection delivers fuel directly into the combustion chamber, where it is mixed with air drawn in during the engines intake stroke. On the Ecotec 2.0L Turbo, the fuel injectors are located just beneath the intake ports. They spray gasoline into the combustion chamber during the intake stroke, where it is swirled with the in-rushing air. As the piston moves upward again, it compresses the air-fuel mixture. The spark plug ignites the mix as the piston approaches top dead-center.
Engineers have long understood the potential benefits of direct injection. The difficulty, until recently, has been technology to make it work properly: advanced fuel and spark timing to avoid detonation, or self-combustion out of sync with the spark; fuel delivery systems that can reliably generate and contain the extreme pressure required for direct injection. The 2.0L Turbos fuel system operates at pressure as high as 2,250 psi, compared to as little as 60 psi in some conventional port-injected engines.
The benefits of direct injection are pronounced. The system allows a more complete burn of the fuel in the air-fuel mixture, and it operates at lower temperature than port injection. That allows the mixture to be leaner, meaning less fuel, more air. Less fuel is required to generate a given amount of horsepower, particularly at part-throttle operation. Bottom line: A turbocharged engine with direct injection can deliver comparable power to a much larger displacement port-injected engine, with significant fuel savings.
Direct injection also reduces exhaust emissions. Other things equal, using less fuel to do a given amount of work means fewer emissions generated when that work is finished. With direct injection, more thorough combustion means fewer potentially harmful emissionsessentially, residueleft to flow out the exhaust system after each combustion cycle.
The Ecotec 2.0L Turbo uses an advanced, electronically controlled turbocharger to increase power. With a turbocharger, exhaust gas leaving the cylinders spins a turbine on one end of the turbo shaft. An impeller at the opposite end of the shaft forces compressed air into the induction system, increasing the amount of oxygen available for the combustion process.
The 2.0L Turbos turbocharger applies a unique, twin-scroll design. Each of two scrolls on the turbine is fed by a separate exhaust passageone from cylinders one and four, the other from cylinders two and three. The twin-scroll design virtually eliminates turbo lag at low engine speedthe time it takes for the impeller to spool up and generate boost pressureand delivers the throttle response of a high-performance naturally aspirated engine
The turbocharger generates maximum boost of 20 psi. Because direct injection cools the intake process compared to port injection, it allows the 2.0L Turbo to safely operate at higher boost and higher compression (9.2:1) than a conventional turbo engine, increasing both output and efficiency.
An intake charge cooler enhances the power-increasing benefits of the turbocharging system. The Ecotec 2.0L Turbos air-to-air intercooler draws fresh air through a heat exchangermuch like a radiator--to reduce the temperature of compressed air thats forced through the intake system by the turbocharger. Inlet temperature is reduced as much as 212 degrees. Cooler air is denser air, which means more oxygen, optimal combustion and more power.
The Ecotec 2.0L Turbos A356 aluminum cylinder head is cast with advanced semi-permanent mold technology for high strength, reduced machining and improved port flow, and it is designed specifically for direct injection. In other Ecotec engines, the fuel injectors are mounted in the intake ports. The 2.0-liter Turbo head has unique injector mounting locations below the ports. Apart from injector installation, the head has conventional port and combustion chamber designs, both optimized for direct injection and high boost pressures.
The Turbos stainless steel intake valves are undercut to improve flow and reduce weight. The exhaust valves have sodium-filled stems that promote valve coolinga technology developed for Powertrains Corvette V-8s. At normal engine operating temperatures, the sodium inside the valve stem fuses and becomes liquid. The liquid sodium improves conductivity, promoting heat transfer away from the valve face and valve guide to the cooler end of the stem, where it more readily dissipates. This helps maintain a lower, more uniform valve temperature, reducing wear on the valve guide for better alignment and a consistent seal between the valve seat and valve face over the life of the engine.
Performance was the priority with the 2.0L Turbo, so its exhaust manifold is manufactured of cast stainless steel. Steel radiates slightly more noise than conventional cast iron, but its extremely durable, and it smoothes the flow of air so exhaust gas can be rapidly expelled.
Continuously variable valve timing (VVT) optimizes the 2.0L Turbos turbocharging system by adjusting valve timing at lower rpm for improved turbo response and more even torque delivery. Both the intake and exhaust cams have hydraulically operated vane-type phasers that are managed by a solenoid and directed by the engine control module (ECM). The phasers turn the camshaft relative to the drive sprocket, allowing intake and exhaust valve timing to be adjusted independently.
Cam phasing changes the timing of valve operation as conditions such as rpm and engine load vary. It allows an outstanding balance of smooth torque delivery over a broad rpm range, high specific output and good specific fuel consumption. Cam phasing also provides another effective tool for controlling exhaust emissions. Because it manages valve overlap at optimum levels, it eliminates the need for a separate exhaust gas recirculation (EGR) system. Variable valve timing can be even more valuable in turbocharged engine. The ECM can adjust valve overlap at low rpm to optimize turbo response, delivering a more immediate rush of acceleration-producing torque.
The 2.0L Turbo cams feature 4X timing reluctors with digital sensors. This state-of the-art control system allows the ECM to accurately measure and adjust valve timing, with consistent performance over the engines anticipated useful life. The cam reluctors work in conjunction with a 58X crankshaft position encoder to ensure the precisely accurate spark timing required of a direct-injection engine. This dual timing system also provides a reliable back up in the event either a cam or crank sensor fails.
Gen II Engine Block
The Ecotec 2.0L Turbo starts with a refined engine block, introduced for 2006 with the Ecotec 2.4L VVT (LE5). The Gen II block was developed with data acquired in racing programs and the latest math-based tools. Both the bore walls and bulkheads, or the structural elements that support the crank bearings, have been strengthened, with only a minimal weight increase (approximately 2.5 pounds). The coolant jackets have been expanded, allowing more precise bore roundness and improving the blocks ability to dissipate heat. Coolant capacity increases approximately .5 liter.
The cylinder block is the engines foundation, and crucial to its durability, output and smooth operation. The common Gen II Ecotec block increases assembly efficiency at engine plants. It also means more efficient cooling, more strength to accommodate the 2.0Ls Turbos increased power, and better noise, vibration and harshness control.
Aluminum Pistons with Jet-Spray Cooling
Pistons in the 2.0L Turbo are cast aluminum, and lighter than conventional steel pistons. This means less reciprocating mass inside the engine, increasing efficiency and enhancing the feeling of performance as the engine builds revs. The tops of the pistons have a dish shape that deflects injected fuel toward the spark plugs, optimizing the thorough-combustion benefits of direct injection.
Each piston has its own directed jet that sprays oil toward its skirt, coating its underside and the cylinder wall with an additional layer of lubricant. The extra lubrication cools the pistons, reducing both friction and operational noise and helping ensure durability to match the 2.0L Turbos high output.
Other reciprocating parts in the Ecotec 2.0L Turbo are enhanced for strength and durability. The crankshaft is a drop forged steel, with induction heat-treated fillets and cross-drilled, chamfered oil passages for racing-grade lubrication characteristics. The steel connecting rods incorporate a larger, forged I-beam cross section for added strength.
High Pressure Cam-Driven Fuel Pump
A high-pressure, cam-driven pump provides the fuel pressure required of the 2.0L Turbos direct injection system. The engine mounted fuel pump is augmented by a conventional electrically operated supply pump in the fuel tank. The fuel delivery system features a high-pressure stainless steel feed line and a pressure-regulated fuel rail, without a conventional fuel return line from the engine to the tank. Fuel pressure varies from about 750 psi at idle to 2,250 psi at wide-open throttle.
Overview
The Ecotec 2.0L Turbo is perfectly suited for high-performance applications like the Pontiac Solstice GXP and Saturn Sky Redlinetwo-place roadsters geared toward enthusiast drivers who put a premium on power. This engine delivers specific outputhorsepower per liter of displacementthat was almost unimaginable from anything other than a pure race engine just a short time ago. Yet the 2.0L Turbo is impressively smooth and tractable in street driving, and like every Ecotec engine, it has been subjected to the toughest, most comprehensive validation process ever carried out at GM Powertrain. It has passed every dynamometer and vehicle test traditionally run by various GM organizations worldwide, not just in North America. The process has included millions of miles of real-world road testing in an extreme range of climates.
The 2.0L Turbo is the fourth North American engine in GMs innovative line of Ecotec four-cylinders, and the most powerful Ecotec to date. It once again demonstrates the sound strategy behind this family of engines often referred to as the global four-cylinders. The Ecotecs harness Powertrains global design and engineering capability by applying the best practices of technical centers in Europe and North America.
Launched for model year 2000, the Ecotec 2.2L created a blueprint for subsequent global powertrain development and such engines as Powertrains global V-6 VVT. It also laid the foundation for a line of engines that share core components with minimal casting changes, yet deliver unique performance and market characteristics with a range of displacements, direct or conventional injection, turbocharging, supercharging, hybrids and front-, rear- and all-wheel drive application in both cars and trucks. At 305 pounds fully dressed, the Ecotec 2.2L is the lightest engine GM has produced in its displacement class, and one of the most compact four-cylinders in the world.
All Ecotecs features durability enhancements and technology familiar in premium V-type engines, including low-friction hydraulic roller finger valve operation and electronic drive-by-wire throttle in most applications. A hydraulic tensioner keeps the timing chain adjusted for life, and extended-life spark plugs deliver 100,000 miles of service. Routine maintenance is limited to oil and filter changes, and even those are made as easy as possible with a paper filter replacement cartridge and GMs industry-leading Oil Life System, which determines oil-change intervals according to real-world operation rather than a predetermined mileage interval. Every engine in the Ecotec line has aluminum-intensive construction and:
Dual overhead camshafts (DOHC) with four valves per cylinder
Twin counter-rotating balance shafts to cancel the second-order vibration typical in four-cylinder inline engines
Direct mounting of accessories like the alternator and compressor to eliminate common sources of noise, vibration and harshness
Full circle transmission attachment and a structural oil
pan that bolts to both the engine block and transmission
bell housing.
For all its design and production efficiencies and multitude of applications, the Ecotec family succeeds for one reason. Each member is world-class four-cylinder that delivers excellent performance without sacrificing durability, economy or smooth, quiet operation.
With 2.1 horsepower per cubic inch of displacement in the 2.0L Turbo, one of the Ecotecs now has the highest specific output of any production engine GM has offered.
2008 Sky Red Line
Direct Injection
Gen II Engine Block
Direct Injection
Gen II Engine Block
Overview
bell housing.
#86
This thread is 5 pages long because really, everybody does care.
And there are other threads dedicated to the SS/T because really, everybody cares.
You see, the SS/T is the high perf Cobalt that is carrying our vehicle into the future.
Which really, is why everybody cares.
Really ...
#88
Really ...
ohhh wait no one cares about what you have to say, really no one cares about you, really, so if you don't care then don't write, really
#91
#93
x2 :P
#94
You decided to write here because, quite obviously ... you care.
That being the case, your self-righteous arrogance is only exceeded by the overtly simplistic mindset you have shown us in your measly 96 posts.
So grow up nub, and be a man.
Really, try it ...
But can you teach mindless juveniles how to think/act like men?
Doubtful ...
***NOTE: Cobaltss/TC has been reported to the mods***
Last edited by firemanfrank; 03-28-2008 at 09:20 PM. Reason: Automerged Doublepost
#95
What a horrible, rotten hypocrite you are.
Really, try it ...
Really, try it ...
ohhh and read my posts next time i was mocking you. not a being a hypocrite. All i care about is providing info, i usually could care less what people think nor do i respond to those comments, but what brings you here if you don't care, just curious, really...
09BlkCrusader
09-09-2015 04:47 PM
