| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| 2.2L L61 Performance Tech 16 valve 145 hp EcoTec with 155 lb-ft of torque Technical Discussions ONLY! |
Thread Tools | Display Modes |
#1 |
Member #: 20825
2.4 intake sound?
right now i have an injen cai, but i'm getting the 2.4 intake mannifold kit soon, does it make any differance in the sound?
#2 |
I think it did. More of a deep WHOOOSH sound. My Cai sounded good before, but now its definitely better now that i think about it.
__________________
2.8, 60s, CA V2 Header, ZZP 3" Dp, Vibrant 3" catback, Devilsown Meth Kit, Intake, Tune by Zach06CobaltSC
![]() 2007 SS Sc Black with Red Inserts. G85 all day! Fastest 1/4 mile in my SS SC- Crappy 14.020 at 99.82 Hot with 100% Humidity (just stg2) Fastest 1/4 mile in my old 2.2- 13.832 at 102.43 mph. 60' 2.356 ![]() |
#4 |
Member #: 3156
It makes the car sound deeper at higher rpm and more "tuned".
__________________
I'm slow.
#5 |
I don't remember a change in sound but probably something, because at about 5k RPm the car hauls the mail
__________________
09 Cobalt SS/TC, Yellow, Stage 1. CrazySteve Intercooler. K&N drop in with snorkel removed..
#6 |
Cobalt The 27th Element
for the 2.4 manifold, on a 2.2 don't you need a tune to make it work properly and not go into linp mode?
#7 |
the manifold won't send you into limp mode, the 2.4L throttle body will though.
We should get that tuned out by Trifecta, but I don't think anyone has tried it.
__________________
#8 |
#9 | |
Quote:
__________________
Mods in VBgarage Local 2.2 to 2.4 Manifold Swap Expert!
I <3 VAG |
#10 |
Interesting, Would the injectors really do much.
I think the generic tunes for the 2.4 manifold can't be that great until Vinch tests one out and tweaks it to death. So if Vince needs help I can help out in 2 weeks. or so
__________________
#11 |
no the injectors wont help with power, but you will lower the duty cycle on the injectors. its pretty much usless, unless your going turbo or sc....
#12 | |
yeah....it's better than the #22 in the 2.2 right now.....
add in the 2.4 manifold, maybe the throttle body, and #32 injectors.....you can probably get 20-30hp N/A....added bonus....since the 2.4manifold is pretty much one solid piece and the 2.2 is two pieces glued together....get a turbo or nitrous you can run a bit more pressure through it... Quote:
it would be good for me since i'm currently building my turbo setup right now....
__________________
I <3 VAG Last edited by FacelessKhaos; 04-29-2008 at 01:01 PM. Reason: Automerged Doublepost |
#14 |
I had the 2.4 manifold and to get the max power i had to run more rich to get power and i bet the test car by 8hp. Vince was so excited
#15 |
i just got my PCV seal today for my 2.4 manifold....so i will be installing it soon...with lots of pics and may even do a how too on it...then take a short video on how it sounds along with the acceleration that comes with it.....all with out a CAI....with the stock air plenum minus the air silencer box located in the bumper/fender well on the passenger side....should be interesting....when i get around to it any way....
but keep in mind that i also did a quick porting/polishing on the throttle body (which makes for less turbulent air flow) and that also aided in acceleration by a couple tenths of a second....just enough to notice and also gives it a better throaty sound..... and if anybody on here experiences the horrible P0223 code (TPS/Pedal position sensor circuit B High Input code...i can tell you how to fix that in like 10 minutes without dropping 405.79 on a new throttle body....it happened to me last week putting the car into limp mode....i opened it up and saw that the contacts on the sensor were not touching the mag surface so i fixed it....so i can help do that....dealership told me that it would take 4 days to repair (3days shipping for the TB and one day to put it on).....but i fixed it in a total of 45 minutes... This is for an 07 LS though....pics in the gallery of what the car looks like so far....w/o the mani installed
__________________
I <3 VAG |
#16 |
Member #: 15758
Is it true that the 2.4 intake manifold just shifts the power upwards?
In other words there is some loss on the low and possible mids?
__________________
THERE WILL BE PUNISHMENT!
#17 | |
has a nine inch
Quote:
if you like, i have some videos of different intakes on my car, PM me, and i'll hook you up. |
#18 | |
Grumble
Quote:
The L61's powerband peaks at like 4800...which is pushrod v8 territory. It can use a little breathing room up top.
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
