help quickly
Old Jun 9, 2008 | 12:49 PM
DomDiggity's Avatar
help quickly
i just took off my throttle body and cleaned it with some tb cleaner. I put everything back on and my car is idling VERY hard andi have no boost when i hit the gas it vacuums with no boost whatsoever. i got engine power reduced on the computer! any ideas!
Old Jun 9, 2008 | 12:51 PM
Joeyavhu's Avatar
Recheck all the connections and check the bolts. Are they tightened down so there is no air leak, and are all the sensors plugged in.
Surging is usually caused by air leaks though, so I would check that first.
D4u2s0t's Avatar
is everything installed properly, tightened, did you let it dry, etc? is the intake hooked back up properly?
Old Jun 9, 2008 | 12:55 PM
DomDiggity's Avatar
all connections are correctly plugged, bolts are tightenedfor no air leaks, intake is properly installed. I let the tb dry for about 30 minutes
Old Jun 9, 2008 | 12:56 PM
Joeyavhu's Avatar
Try unplugging the PCM for about a minute, then replug it in and try starting it again.
Old Jun 9, 2008 | 01:00 PM
DomDiggity's Avatar
I unplugged the battery for 15 minutes
Old Jun 9, 2008 | 01:03 PM
Joeyavhu's Avatar
Hmm... Did you intake filter possibly fall off? It is surging, right? Are any codes being thrown?
Old Jun 9, 2008 | 01:10 PM
DomDiggity's Avatar
ok i plugged the battery back on, turned the car on and no CEL no engine power reduced, started and idled fine. Thanks guys for the help I ngot really scared there for a minute!
Old Jun 9, 2008 | 01:20 PM
Joeyavhu's Avatar
Yea, sometimes the PCM just needs a good nap to get everything back in order. Lol. Thats what I did when it tossed up Crankshaft codes.
dennis69
Oct 20, 2015 07:39 AM
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
