Syclone #2213 My project (pics)
Old Jul 12, 2008 | 10:47 AM
R&C_rallySS's Avatar
Race Prepped Short Block:
Block bored on precison stand & 2 step torque plate honed
Speed Pro "Plasma" moly piston rings; file fit
Diamond Custom 2618 Forged Custom Pistons
Eagle H beam connecting rods
Federal Mogul Super Duty Alloy Main and Rod Bearings
Federal Mogul cam bearings
Speed Pro double roller timing set
Comp Cams custom grind Xtreme Energy hydaulic roller camshaft
Comp Cams Magnum hydaulic roller lifters
Comp Cams valve springs
Pro Gram Engineering splayed bolt, 4 bolt center caps, convert to 4 bolt main bearing splayed bolt block
ARP coonecting rod bolts, main studs
Degree in cam
Hot Tank block, heads, misc., install new core plugs
Precison ground crankshaft, nitrate treated
Balancing rotating assembly
Align bore main saddles
HD oil pump w/HD driveshaft
Engine Gasket set (includes "GM" head and intake gaskets specific to the Syclone/Typhoon)
Heads and Valve Train:
Competition valve job on original cylinder heads
HD vavle springs matched to camshaft
Comp Cams Magnum Roller tip rocker arm kit, 1.6:1 ratio
ARP head studs
Cylinder head resurfaced
Engine Professionally assembled
Later this was changed to Brodix heads from what I understand because the mech. said you won't get much out of that.
Looks like on the receit the following was added as options:
Brodix cylinder heads (Manley pushrod guide plates and screw in studs)
Bowl and Chamber port work
Full competition port work
Transmission Rebuild
Rebuild Custom Supplied 700R4
Syclone/Typhoon to Street and Strip
Specs for use with lock-up Torq Converter
Persicion Industires 9.5 L/U Torq Converter
Hi-Pro trans Upgrade
Includes billet servos, wide band, beast sunshell? Racing 3-4 Clutch pack, servo CK vavle?
5 pinion planets Front and Rear
Rebuild Transfer Case
Includes new front career, input shaft, planet and chain
Corvette Governor (5200 rpm shift)
Other Stuff
Set of 50lb Fuel injectors
3 bar map sensor
O2 sensor 3wire
wastegate kit
2end Alky nozzle kit
plugs 3 sets
Exhaust band clamp
EGR block off plate
FAST fuel injection mangement system
fuel injection wire harness
EST Spark Module
Engine Mounts
Upgraded Turbo and Other Stuff
TE45A
66 intake wheel
.63 Prescion exhaust
Hi Torq Starter
Custom Built Stainless headers
3" Race gate Downpipe
Turbonetics Racegate wastegate
Don't mind the dirty garage and dirty truck
Autometer Phantom Pyrometer, Fuel Press., and Boost Gauges
I want to get Oil Pressure, and Water Temp. also.
One of my problem areas, got hit by a deer, just cracked the front a bit.
TE45A Turbo
Yes, I know I need a new belt ASAP :rant:
When its finished, would like over 500 all wheel hp. Should look something like this:
Also, red ghost flames instead of blue...not sure yet...
Old Jul 12, 2008 | 10:52 AM
heyitsmikey1987's Avatar
i hate you i want one of these so bad
Old Jul 12, 2008 | 10:54 AM
Gotenks's Avatar
Nice truck... I like everything but the flames.. but to each their own..
Old Jul 12, 2008 | 11:01 AM
Well, I always wanted a 1969 Camaro RSSS but I know I can't afford one. I never thought I would be a owner of a Sy because of how limited they are. More limited then even most muscle cars. Right now is a good time to buy a Sy or Ty because of the Econmy. Seems most of the trucks are going for less then they did a few years back. I think that will change though once things get back on track. Blue book value is amazing on these trucks. Lower mile trucks in good cond. are values over 15k.
I plan on keeping this forever and slowly finishing the project. I need bigger injectors, front mount IC, plugs/wires, need to weld a crack in the manifold, paint job, tint windows, get rid of all the unneeded stuff in the engine bay such as heater hoses and plug what I don't use, oil pressure gauge, water temp gauge, and another tune. She puts down over 400hp right now.
ty, yea I agree. I think without flames is just real nice a clean.
Last edited by R&C_rallySS; Jul 12, 2008 at 11:01 AM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 11:03 AM
hatrickstu's Avatar
sick truck. get it cleaned up and you will love it 50times more
Old Jul 12, 2008 | 11:04 AM
sn!perwolf's Avatar
Definatly a clean project man!
personally i like an s10 (er s15 i guess) with a nice SBC with a big set of slicks under the back but like Gotenks said.... to each his own :P
Old Jul 12, 2008 | 11:05 AM
hatrickstu's Avatar
why would you want to rock slicks when you have a sick awd setup? rock the sleeper-ware as long as possible
Old Jul 12, 2008 | 11:06 AM
red06s/c's Avatar
My uncle has a 1968 rsss sitting in his garage, its pretty badass, love the truck tho!
here a video on one racing a strt-4. http://youtube.com/watch?v=H5UIaFZxIhg
Old Jul 12, 2008 | 11:39 AM
ralliartist's Avatar
nice truck, I love those.
Old Jul 12, 2008 | 11:44 AM
boostedss26's Avatar
dude ive wanted a sy for the past 5 years. And as for ghost flames their a big misunderstanding. Ghost flames are not a style of flame, their are when you add pearl lets say black cuz your truck is black and you can only see them from an angle i 'm a painter for a liveing
that's not a stock snail is it?
Last edited by boostedss26; Jul 12, 2008 at 11:50 AM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 11:52 AM
LaserblueSS's Avatar
wow sick truck bro. i would love to get one of those as a project later in my life. good luck with it man! keep us posted.
Old Jul 12, 2008 | 11:53 AM
deafinatly keep us posted
Old Jul 12, 2008 | 11:56 AM
all4glh's Avatar
How long have you owned it? I've tried to find one of those in my budget a few years back but had no luck. Nice car.
Old Jul 12, 2008 | 12:18 PM
DeftonesFan867's Avatar
IDK where you would get the idea that it would be a stock snail, and they weren't slow stock either.
BTW I used to live near Rhinelander.
Old Jul 12, 2008 | 12:20 PM
Yes, I know what ghost flames are
Anyways, it is not a stock snail
Here is my mod list so far with the engine. There is over 20 grand in receits in my folder here at home.
Degree in cam
ARP head studs
Other Stuff
3 bar map sensor
O2 sensor 3wire
wastegate kit
plugs 3 sets
Exhaust band clamp
EGR block off plate
EST Spark Module
Engine Mounts
TE45A
66 intake wheel
Hi Torq Starter
Both the Syclone and Typhoon (SyTy) trucks featured a Mitsubishi TD06-17C 8 cm˛ turbocharger and Garrett water/air intercooler attached to a 4.3 L LB4 V6 engine with unique pistons, main caps, head gaskets, intake manifolds, fuel system, exhaust manifolds, and a 48mm twin bore throttle body from the 5.7 L GM Small-Block engine. All SyTy's had a 700R4 (4L60) 4-speed automatic transmission. A Borg Warner all wheel drive 1372/4472 transfer case split torque with 35% forward and 65% to the rear wheels. Both trucks featured sport modifications to the standard suspensions. The Syclone was the first production truck to receive a 4 wheel anti-lock braking system. Output was 280 hp (209 kW) and 360 ft.lbf (488 Nm). The Syclone, when new, was capable of accelerating from 0-60 mph in 4.6 seconds and could do a quarter-mile run in 13.4 seconds at 98 mph (153 km/h)
From Wikipedia.
Old Jul 12, 2008 | 12:24 PM
13.4 Stock 1/4th mile times back in 1991
I have owned it since April. There are a few Sys out there for sale right now. I was not looking for something mint and in stock form. Those bring top dollar. If your looking for a project with some mods already and want a drag/street truck that is the way to go. If your a collector and want to store it away, get a oringal low mile truck. Just my .02
Last edited by R&C_rallySS; Jul 12, 2008 at 12:24 PM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 12:26 PM
ls1fbody's Avatar
Haz l33t wheelz.
thats pretty damn fast for a stock truck in '91. clean truck, wasn't always a fan of fast trucks, but they're startign to grow on me. isn't there someone else on here building one?
Old Jul 12, 2008 | 12:27 PM
07 SS/SC's Avatar
******* sick!
Old Jul 12, 2008 | 12:46 PM
Originally Posted by 07 SS/SC
******* sick!
Thanks, its not as sick as I want it to be yet. When it is complete, I'll post of more pics and some vids
Old Jul 12, 2008 | 12:51 PM
suburbanrobot's Avatar
NIIIIIICCCCCCCEEEEEE!!!!! I almost bought a Tyhpoon a few years back.... they both rock!!! great vehicle!!! I think it looks better in SLEEPER stock mode!!! best of luck... keep us updated
Old Jul 12, 2008 | 01:21 PM
all4glh's Avatar
I biggest thing for me was trying to find one with no rust.
Old Jul 12, 2008 | 04:55 PM
Antz97znj's Avatar
vette killer of the early 90's...nice, always like those an typhoons
Old Jul 12, 2008 | 05:42 PM
Snail meaning turbo i know their fast trucks ive been wanting one for 6 years
Old Jul 12, 2008 | 05:48 PM
ssmokin's Avatar
i say keep it the way it is. just paint the lower molding.
