New MRZ 2.0 LSJ Lightweight Crank Pulleys just released!
We just released the New MRZ Lightweight Crank Pulleys
Same diameter as OEM to keep boost level constant, but 2.5 times lighter than the OEM cast iron GM pulley! this pulley will help free up extra HP from your engine with this huge saving on the crank rotational mass. This is one of the bang for the buck modification you can add to your engine and it's also easy to install in 30-45 minutes depending on your mechanical skills.
OEM WEIGHT: 1830 Grams
MRZ WEIGHT : 730 Grams
2.5 lighter than OEM ! Now that's a radical drop on the rotational mass of your crankshaft meaning your engine will get to revs faster.
Link: http://mrzperformance.vstore.ca/prod...roducts_id/139
$174.95
Last edited by MRZ - RedGTZ; Aug 21, 2008 at 12:42 PM. Reason: Automerged Doublepost
We will get someone to compare the numbers soon on the Lightweight LSJ pulley but the HP gain should not be more than a couple HP since it's the same size as the OEM pulley, the real gain will come from the rotational mass reduction, our pulley weight 2.5 less than the OEM pulley, this will help your engine revs faster since the rotational mass is readuced
If we get 10 people or more we are ready for a group buy anytime
Last edited by MRZ - RedGTZ; Aug 21, 2008 at 12:59 PM. Reason: Automerged Doublepost
MRZ Billet Crank Pulleys for the NA ECOTEC's 2.2 and 2.4 are ready! LE5 L61
We are proud to bring you another high quality performance product for the Ecotec
Link to MRZ Performance Underdrive Crank Pulley - UDP : http://mrzperformance.vstore.ca/prod...roducts_id/144
OEM WEIGHT: 1650 Grams OEM DIAMETER: 6.500"
MRZ WEIGHT : 590 Grams MRZ UDP DIAMETER 5.875"
3 X lighter than OEM ! Now that's a radical drop on the rotational mass of your crankshaft meaning your engine will get to revs faster.
MRZ billet aluminum UDP versus OEM cast iron pulley:
Link to MRZ Performance OEM size Lightweight Crank Pulley: http://mrzperformance.vstore.ca/prod...roducts_id/143
MRZ WEIGHT : 700 Grams
Satisfaction guaranteed like on all MRZ Performance products!
Just contact me if you have any questions
Thanks for looking!
