Need some help with my turbo setup
My car has been acting weird lately. Anything above 6k and the power goes to ****. SO i've been shifting below and it works fine. So, I hit the rollers today to try to tune it out and this is what I found.
When at good boost like 18+ It hold until about 5k where i get 275whp after that boost drops slightly and it holds the power until 6k. @ 6k it immidiatly drops off hard. You can hear and feel it. It sounds almost like a revlimiter. When it happens the afr stays correct and it knocks about a degree. If you look at the log you can barely notice anything but when you look at the dyno graph and listed to the car there is clearly something wrong.
So, i took it back to 10psi. I got about 230whp and it kept pulling to redline. No sign of any problem. I checked the plugs. They are all gapped at .28 (bkr7E coppers)
There doesn't seem to any boost leaks the charge piping is real short. I am just stumped. Anyone have any ideas?
My wastegate is a synapse engineering synchronic wastegate, maybe the source of the problem? I am also still using a draw through MAF setup IDK just ideas.
Help me out guys...
Help me out guys...
.028 if fine for that setup.
Sounds like either your waste gate spring is too low (need at least a 1 bar so it doesnt' drop off like that), fuel pressure problem, or your turbo is just running out of steam. whats the a/r of your hotside
The turbo is plenty capable. I know because I've overboosted a few times, It's a hell of a ride until the charge pipes blow off. I know that has more in it.
It's only a .48 hotside but it should be cutting out at over 320 not at 280hp.
The IDC is only in the 60's so IDK it could be a feul pressure problem. Now that you mention it, I have never changed my fuel filter. I know it's passed due. Maybe that could be holding back some fuel flow at high boost and screwing me up?!?
The wastegate has been giving my trouble from the start. I'm going to look into other options.
Keep the idea coming ... thanks guys!!!
Also I get more boost on the street than on the dyno. Something is seriously wrong.
That might be an issue holding me back, but it's not this problem right here. The car just hits a wall. It's almost like an ignition revlimiter. It just dumps power pops and shoots flames. It's very violent.
sound like a fueling issue... happen @5800 rpm?
