New Product-New Design of Buffing Pads
Old Nov 16, 2008 | 12:17 PM
Turbo Wax's Avatar
NEW Product - New Generation of Foam Pads-Center Ring Foam Pads
Permanently Mounted on Pad
8.5' Total Diameter
Velcro Back with Centering Ring
New innovative foam pad design that is safer and faster. The new design is a recessed back flexible ring permanently glued on the Velcro side so the backing plate is centered on the pad every time. You can center the plate one just one hand in seconds and the center ring prevents the backing plate from cutting threw the foam pad and making contact with the paint. Another benefit of the center ring is that when you have a true centered pad on the polisher the final finish is even and the technician will have less fatigue in their arms.
The face of the center ring pads will have a hexagon cut design which will allow for the chemicals to be distributed better while buffing and keep the heat down as well.
What separates us from the rest is that we don’t just lay sheets of foam with Velcro and die cut them, we manufacture our foam pads with recessed backs to protect and eliminate any accidents a technician can do while buffing. Flat pads are great but if you have an exposed backing plate edge you can hit the paint and cause damage that will set you back.
New generation of buffing pads, hexagon squares that will help trap the polishes while buffing and reduce the heat buildup when the user is buffing. The hexagon pattern on the pads also helps distribute the polish more evenly giving you a better finish, special black ring on the back of the foam pads is to center the backing plate, provide protection from the backing plate making any contact on the paint,foam pads are made from the BEST materials . Made in U.S.A.
Ring provides instant one hand centering
Ring prevents backing plate cut threw
Ring system is fully washable.
Old Nov 26, 2008 | 12:46 PM
Coop's Avatar
Cool what is the price and which densities will you have?
Old Dec 1, 2008 | 03:26 PM
Turbo Wax's Avatar
Yellow Foam Pad- Use for Heavy duty Compound
Orange Foam Pad- Use for Light duty compound
White Foam Pad- Use for Polish
Green Foam Pad- Use for Compound/Polish
Black Foam Pad- Use for machine Glaze
Blue Foam Pad- Use for Polish/Sealant
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
